Question about ASUS P4P800 SE (890552603657) Motherboard
Trying to fix old computer
Trying to install hard drive. but I can't get the video card to show me the bios. I turn on the computer but nothing happens. I have this computert, it was getting me to the bios, and being able to view everything, but when I removed the motherboard from old case and installed to new case without connecting anything except same video card I now cannot view anything
  • 2 more comments
  • dr_partridge Dec 29, 2008
    I would if I could, but I can't, as there is no internal/onboard graphics port on the back of the computer. Thanks for the effort
  • dr_partridge Dec 30, 2008
    When I remove the external display card, I can boot my machine, but can't disable the on board display and , as I said nowhere to plug monitor into the back of the computer, so how can I see to disable the none existant onboard display card?? I'm sorry, but your answer is either confusing or incorrect.
  • dr_partridge Jan 02, 2009
    Can anyone else suggest what I can try or explain abhi patil's comments better to me as I'm really stuck, and am thinking of just giving this board the heave ho and buying another one
    Thanks
  • dr_partridge Jan 05, 2009
    Well I think I can see why I can't get any help or the correct help I want on this site. You have to pay well guess what. I shall just take my woes and go elswere and spread the news to people not to rely on fixya.com site for help
    Master:
  • 568 Answers
Remove the external display card boot ur machine with on board then disable the on board display and then install your external display card and then connect it to the monitor
Posted on Dec 29, 2008
  • Abhinandan  Patil
    Abhinandan Patil Dec 30, 2008
    read my solution properly i never told u to do anything or reading nething on back of computer
Do not show VGA
It's an old model, 1 - CDrom and HDD lights blink? if not please try turn on without the cmos battery. IT's an 11 year old pc the battery is almostly dead. 2 - CPU fan turn on loud and doesn't low rpm? Fan dirt or bad motherboard.
Mar 12, 2014 | Computers & Internet
My Hp dc5000, once turn on, does not show anythiong on the monitor screen. I see the hard drive loading but nothing shows on the monitor. I taught of the internal video card. I installed an external...
If you're sure that monitor is good, you're on the right track, BUT, you can't install an external video card without first getting in to the OS and installing the drivers. If you meant you added a video card, you still have to get into the CMOS portion of the BIOS to change over to the new card, if the BIOS is not set to automatically detect the card.
Try going through the Clear CMOS procedure for your computer, usually a matter of jumpering some pins on the motherboard - or removing the button cell battery for a period of time (15-30 minutes) with the power cord unplugged.
Jul 07, 2011 | Computers & Internet
I installed a new hard drive in my PC. It installed itself after I turned on the computer but it doesn't seem to show up on My Computer as a individual drive. BIOS and the Sys Info recognizes there is a...
Are you sure your BIOS is not showing the old hard-drive you had before you installed the new one?
On the new hard-drive you bought, do the following step
there should be a jumper that came with it, put the jumper to "master",
if that didn't work, put it to "slave", if that didn't show up, put it to "cable select" and try it.
If all failed, totally remove the jumper and try.
Also check in the BIOS to make sure that the Drive is not disabled.
This seems to be a problem from the jumper.
Please rate 4 stars if this helped you.
Apr 26, 2011 | Seagate HDD 1TB 7200RPM SATA600 32MB 3YR...
I am trying to install a pcie-x1 video card on a ibm eserver x206m i salvaged from work. I am running windows 7 64bit . I have tried to turn off on board graphics so that it takes the video card i just...
I know this is really old, but I had the same problem on my 206m 8584 with a pci-e x1 video card. I had to upgrade bios first, but nothing seemed to change, bios only showed onboard video as option and windows perfectly recognized the exta card. I went to windows video settings, it showed both video, onboard as main and active and extra as inactive, changed the second video to main and active and switched the plug to finally see my enhanced video. Only problem is that bios screen won't show up on pci-e card, so I start seeing something only after one minute :) Hopes this saves someone else some time.
Nov 03, 2010 | IBM eServer xSeries x206m
HP a1600n desktop will turn on but will not boot. Does not run thru BIOS, keys/mouse check. HDD spins up, CDROM goes thru check then just sits. Monitor doesn't kick in because doesn't get to video check. ...
you can try buying a cheap pci express video card and install it inside one of those slots and connect your monitor to the new video card and see if it will boot up. some computers have a beeping sound if something is wrong. if theres no beep then try to remove everything like memory and hard drives and just leave the power supply. if it still doesnt beep when you restart the computer, then it might be the motherboard.
Mar 28, 2017 | HP Pavilion a1600n (882780776265) PC...
Pc turns on but nothing come on the screen.tried several things such as,substituting parts like the power supply,processor,memory,hard dirve.I also cleaned it.the only thing left is to try a pci express...
if nothing was showing up on the screen I would have checked the Video card first as its one of the simplest things to check but you need to borrow someone elses.
The light would be on cause the BIOS is looking for a hard drive. If you connect speakers or headphones see if you can hear windows booting up if there is something installed on it. If you can hear windows starting up good! its probably your video card. If nothing then your motherboard might be the culprit.
Apr 05, 2010 | Everex GA3400 Refurbished AMD Desktop...
My computer will not boot properly or show video with new radeon hd 4550 card installed. How can I fix this? I've unistalled previous card's drivers and think I've disabled on board adapter, but its still...
The pci express slot on that computer is an option, so it may not be enabled automatically when shipped, I would suggest rebooting and go into the BIOS settings and make sure the PCI slot is enabled. Then strile F10 to save and exit, reboot and try it again.
Jan 11, 2010 | Gigabyte RADEON HD 4550, PCI Express...
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
Tried Installing new Hard Drive, Now no picture
see the hardrive cables and also check that jumpers in hard drive just connect one hard drive at a time first ok set jumpers to master settings and then try if the problem persists
Try changing RAM it is the main culprit if ur computer is unable to boot and ur vga is ok as u told me
pls do rate me if it helps or fixed ur prob
Feb 24, 2009 | E-Machines T4155 PC Desktop
Disconnect the drive and see if your video card works. If not, something else is broken. Could be the video card, the motherboard, processor or power supply. It is possible for a power supply to fail in such a way that it destroys everything connected to it. If that works, you have made some mistake hooking up the hard drive or it is badly damaged. Hard drives have jumpers that must be set correctly to indicate whether it is a master (1st drive on the ribbon cable) or slave (2nd drive on the ribbon cable). The ribbon cable must be correctly oriented with the red strip going to pin 1 (pin 1 should be marked in very, very small print on the drive's connector).
Sep 10, 2007 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
