When I switch on my lg top loader, the machine starts and then trips my earth leakage switch, leaving me without any electricity.
  • 15,935 Answers
It appears your timer/control board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
When I put the top down as it clicks in it trips the mains lve tried different plugs in the house with the same result
YOUR CIRCUIT BREAKER MAY BE A RCD SET TO TRIP AT
250 M-AMPS VERY SENSITIVE
TO ME IT LOOKS LIKE YOU HAVE A ELECTRICAL COMPONENT OR CABLE SHORTING TO EARTH ,COULD BE SOME DAMP GOT IN SOME WHERE AND IS CAUSING A VERY SMALL ELECTRICAL LEAKAGE, HENCE TRIPPING THE CIRCUIT BREAKER. OR IT COULD BE A COMPONENT FAULT
PROBLEM COULD BE THE LID SWITCH ,GOT WET OR FAULTY, AND IT COULD BE COMPONENT AS PUMP OR MOTOR , AFTER YOU USUALLY CLOSE THE LID WHAT HAPPENS NEXT, DOES IT START FILLING WITH WATER/ COULD BE WATER SOLENOID VALVE FAULTY , WHAT I AM TRYING TO SAY IF YOU CAN REMEMBER WHAT HAPPENS AS SOON AS THE LID IS SHUT ,THAT'S WHAT MAYBE THE THING THAT IS SHORTING OUT, OR IF NOTHING HAPPENS WHEN YOU CLOSE LID NORMALLY UNTIL YOU SET UP CONTROLS
THEN THE PROBLEM COULD BE THE LID SWITCH OR WIRING TO IT FROM PROGRAMMER HOPE THIS IS SOME HELP. PS LEAVE IT OVER NIGHT TO DRY OUT IT MAY CLEAR IT'S SELF. GOOD LUCK
Nov 15, 2016 | Washing Machines
Forgot to open water supply for my new washing machine and when it started flashing I only realized the problem.As soon as it washes it trips my main switch and says Earth Leakage????Please help!!!!!
Hello Dora,
An Earth-leakage circuit breaker (ELCB) is a safety device used in electrical installations with high Earth impedance to prevent shock. It detects small stray voltages on the metal enclosures of electrical equipment, and interrupts the circuit if a dangerous voltage is detected.
You should have an appliance service person come out for a service call since there may be a dangerous shock hazard present on the machine.
Thanks,
Mario
Apr 17, 2016 | Washing Machines
When plugged in its tripping my electrics,i changed the fuse it worked, when i tried to use it again it has tripped my electrics
have the electrics tested for earth leakage ( faulty lead insulation, pest infestation across points etc)
the tripping indicates a electrical problem and is tripping out before some one gets electrocuted.
May 19, 2015 | Washing Machines
Ground leakage detected device cut the power
Take wires out of plug and the wire from the connecter box of machine. With multi tester test earth to live and earth to neutral. If there is a short circuit it will show on which wire it is. Next disconnect live and neutral wires from motor and run test on all wires. If no short the motor is faulty and test the motor connectors. If the short is not found the motor is not the problem but the control system. Disconnect all wires from controls and test everything isolated and individually.
Apr 16, 2013 | Washing Machines
The machine shorted my electricity
without more info it is difficult to suggest remedies.
possibilities include water leaking onto electrics in the machine, or a faulty heater element in the bottom of the drum causing earth leakage tripping the breakers.
others include loose/broken wires, dust from the carbon brushes in the motor causing shorts or motors drawing too much power.
it would help if you could tell us if there is a particular point in the cycle when the problem occurs.
Feb 19, 2011 | Washing Machines
Every time i press the start button and the water starts it trips my main switch i have replaced the mains suppressor and the fill valve but it still does it can you help. john matthews
It sounds like there is water leaking onto the electrical circuits and tripping the earth leakage switch. Make sure that there are no leaks inside the machine and that all the wiring and circuits are dry before trying then machine again. A hair dryer is very good for drying out circuits.
Feb 18, 2011 | Washing Machines
My washing machine trips the Earth Leakage circuit breaker. By overriding the earth leakage the machine runs well with no problem but I do know that this is dangerous and that I have created a hazardous...
Actually, dont be in a rush to replace the motor. Check the heating element. 90% of the time its that. Motor is very rarely the problem. Disconnect the 2 element terminals and let machine run for a reasonable time. If no tripping out takes place, it confirms the element is faulty.Im assuming you have the front loader. The top loaders have there own issues.
Aug 05, 2010 | Whirlpool Washing Machines
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Jun 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Bosch WFB2005 triping mains
get yourself an insulation resistence tester and put one lead on the earth pin of the mains plug select continuity on the tester and touch any bare metal on your machine it should beep. After put the lead that you connected to metal on the live pin of the plug close the washer door turn machine on.Now select 500 v on the tester and press the ideal range must be above 2 meg ohms with a minimum of 0.5 ohms if you get a reading below then you have a prolem with the washer, but if above 2 meg ohms it maybe your mains socket. Good luck
Mar 02, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Richard Roth
Richard Roth
