Question about Creda IWD12 Front Load Washer / Dryer
A Creda condenser dryer TCR2, it went off won't work at all now
Creda condenser dryer TCR2, switched off and won't work at all now. Think filters may be blocked/full, but have no manual so do not know where to find them! Does anyone know where the main filters are, or where I can find a user manual to find out???
Many thanks
There is a pressure sensor on the inside of the dryer if the pin on the door isn't applying enough pressure it wont work try pushing something in the switch with door open to see if the dryer works then you know it's the pressure switch thats the problem
Posted on Jan 19, 2012
If your dryer has stoped and after cleaning the filter it still dont work, get a hair dryer and take the back panel off which houses the heater element and if you can see its damp dry it with the hair dryer till its all dry and then it will work agin
Posted on Mar 12, 2010
  • Creda Master
  • 3,463 Answers
There is a lint filter inside the front of the m/c.
A filter at the bottom left of m/c,undo catches to release it, remove it and wash out under running water to thoroghly cleanit.
.Remove water container at top left front , and empty.
Make sure air intake and air out lets are clear, one at front right, and one at rear of m/c.
You can download user instructions.
Goto;;
www.hotpoint.co.uk
Click on (after sales), click on download user instructions, and follow the guide
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
Cold air from my tumle dryer. I've taken off the back of my Creda TCR2 and the elements look fine - not tested the wiring but was wondering where the thermostats were as I've read that you are...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
My creda model tcr2 isnt drying my clothes
heatman101
Jul 30, 2011 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
My creda tcr2 condenser dryer is not turning with a load but does turn without a load or will turn with a little push can you help
It is going to be 1 of 2 possibilities.
1--A faulty start capacitor.
2--A slack or drive belt.
More likely to be the capacitor, located at bottom rear right of dryer looking from front.
It entails removal of top cover and right hand side panel to gain access
Please rate my solution.
Thanks.
Nov 17, 2009 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Can you supply an instruction manual for a creda simplicity condenser dryer TCR2
Try this website, maybe you will find out what you need.
I hope this helps
Clothes Dryer how-to instructions. Clothes Dryer help.
laundry.manualsonline.com/manuals/device/clothes_dryer.html
Oct 03, 2009 | Dryers
No heat from dryer
there are ways to the element disconnect the power, then get to the element from the back of the dryer. disconnect the 2 wires on the element and use a muti meter. find the ohm section on the meter(it will beep when you connect the test leads) . connect the test leads to the element, if the meter does not do anything the element is bad.
Apr 14, 2009 | Dryers
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Creda IWD12 Front Load Washer / Dryer Logo
492 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
