Question about Hotpoint Washing Machines
Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Our Hotpoint wt540 washing machine is not finishing off a wash. We get a flashing Rinse hold and Mini load led along with the on/off led. water is left in the drum and the clothes are not spun. What is the problem. Pump filter is clean. no obvious blockages.
  • Anonymous Mar 31, 2014
    clothes and towels feel not rinsed after cycle
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Posted on Jan 22, 2009
  • samirbandali Dec 11, 2010
    Hi Could you confirm if it was the same lights mini load, Rinse and on/off light. also it tends to start and makes a noise.
    I have exactly the same problem - I am thinking of ordering the board from and fitting it myself.http://www.emwelec.co.uk/index.php?actio...
The problem is not with the board. This is a error code showing the board is working. Take the following steps.
1. Open the filter at the front bottom of the machine and clear the filter. If the problem is still there then the blockage is higher up. go to step 2
2. Turn the machine on its side to get access to the bottom of the machine. Follow the pipe from the filter.
3. Remove the clamps on the pipe and remove it. There should be a ball in the pipe make sure it goes back in. Check for a blockage in the pipe and the areas it connects to.
4. Put everything back together and test it.
Posted on Oct 14, 2012
    Problem Solver:
I have exactly the same problem - I am thinking of ordering the board from and fitting it myself. http://www.emwelec.co.uk/index.php?action=itemI have exactly the same problem - I am thinking of ordering the board from and fitting it myself. Mine also makes a noise http://www.emwelec.co.uk/index.php?action=itemI have exactly the same problem -
Posted on Dec 11, 2010
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
On/off button and mini load LED's flashing ON Hotpoint WT540
Make sure there is no water left in m/c, lay hose down to draln completely, try spin again, if still no go, remove motor and check brushes.
Dec 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Problem with wt540
Have you actually tried to pump water out, if you select a drain only position or drain and spin ,and hold the drain hose into a bucket or into the sink, you should see water pump out.
If it does not ,then you have a blockage somewhere, or your pump is faulty, assuming of course that the pump is getting power.
Plz leave feedback.
Ta
Dec 10, 2008 | Washing Machines
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
760 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
