2005 Chevrolet Cobalt Logo
Jayme Probst Posted on Oct 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 chevy cobalt stalls when foot is off the gas
It never stalls when giving gas. only when foot is on the brake. the rpm dial goes up and down when at a stand still. The meter fluxuates between 500 and 1000 rpms and dips below 500 causeing the car to shutoff. It also shuts off when driving down the highway
Mike Mathias
Level 2:
  • Expert 56 Answers
  • Posted on Oct 02, 2012
Mike Mathias
Expert
Level 2:
Answers
56
Questions
7
Helped
8881
Points
156
U may have a brake booster leaking vacum when u apply the brake its useing vacum from engine see if u can hear a hissing sound when apllying brake if so thats ur problem
5 Related Answers
Anonymous
  • 962 Answers
  • Posted on Feb 06, 2009
SOURCE: 89 Chevy Corsica keeps stalling while driving
. Have it checked for a trouble code. It seems like a sensor problem. ( Idle position , crankshaft position, camshaft position sensors could be bad. Also the EGR valve could be bad. with a caode you can narrow it down a bit.
Anonymous
  • Posted on Jun 05, 2009
SOURCE: wont keep idle, car stalls out
I had this same problem on my 2005 monte carlo, took mechanic a while to figure out it was the idle air control valve. They also replace the idle air control motor.
Anonymous
  • 1959 Answers
  • Posted on Jun 18, 2009
SOURCE: Cobalt not running at low rpm.......
All are possibilities but EGR valve makes the most sense. It's famous for causing poor idling and/or stalling at low RPMS. Best of luck.
Greg
Anonymous
  • 63 Answers
  • Posted on Jan 06, 2010
SOURCE: 2005 chevy cobalt, car wont start ... check
disconecting the battery should reset the pcm. but you will need to find out what caused the problems.
ZX2Fast
Brad Kirby
  • 547 Answers
  • Posted on Mar 05, 2010
SOURCE: My 98 Chevy Malibu v6 3.1 liter engine high idling
You probably have a large vacuum leak. With the engine running, listen under the hood for a hissing sound. Check all of the rubber lines running from the intake.
1977 dodge motorhome. The choke isn't opening all the way when I step on the gas so it stalls . What can I do?
possible faulty brake booster ( putting your foot on the brake) indicates a vacuum leak and idle rpm too low
What would cause my 2005 Chevy Cobalt to have to be placed in reverse, then to drive to get the vehicle to accelerate?
Some problem in the valve body most likely. Do you get any fault codes when you scan the engine/transmission control module?
Why is my engine idle going up and down?
clean the idle control sensor and throttle body
RPM goes up then down when slowing down
my 07 Tc does this also not sure why, but it helps me brake, could be that it is coming out of passing gear, and going back to last gear
My 2005 chevy cobalt rpm drops very low when coming to a stop. I changed the Oil and Plugs and it helped a little bit. PLEASE HELP
first check the throttle plate for carbon build up the look for the knock sensor harness rubbing onto the fan shroud
1helpful
Stalls when placed in reverse
well you have convertor lock prob prob a sensor for trans let me know hey till fix ya bouy me ok
2answers
My Cherokee stalls when I let off the gas
turn up your ile (rpm's) or your fuel filter is going bad, and it is not getting fuel which causes it to stall.
Most likely problem is dirt in the idle jets. If so, your carb needs a bit
of a cleaning.
As a temporary workaround, crack the gas open just a bit with your foot (so
it idles at 1,000 rpm or so) as you brake to a stop, then hold your foot on
the gas to keep it alive. This is an iffy proposition though, since you'd
have to brake with your untrained LEFT foot.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
