Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Loading belkin G adaptor
When loading disc then add adaptor it keeps askin 4 user name and password .onto laptop e-system.
    Guru:
  • 1,894 Answers
Give the default user name and password.
if that does not work please reset the device and use the default user and pass.
thank you
Posted on Dec 29, 2008
DO NOT HAVE USER NAME OR PASSWORD TO STARTUP ACER LAPTOP. I purchased the acer second hand and was not given the user name and password. How can I start up my Laptop? I do not have a boot disc either. ...
there is one way left hope this works.
please follow the method given below.
1. as u turn the computer keep hitting F8 key on your keyboard.
2. by doing this you will see advanced boot option.
3. select safe mode by using down arrow key. and press enter key (Return).
3. your computer will be started up in safe mode.. there you will find another user name Admin or Administrator.
4. Click on that if it loads up you can change the password of existing account or you can create another account and use it.
if it doesn't work. you have to re-install the operating system.
Jun 24, 2011 | Acer Aspire 5315-2191 Notebook
How can i open my belkin router upnp
You will have to log in to the setting of the router. This is accomplished by typing the ip adress of the router usually 192.168.1.1 or 192.168.0.1 into a web browser. It will then ask for a user name and password: the default user name and password for belkin routers is: User name: Admin Password: (Leave the Field blank). Then you can enable UPnP in there. UPnP stands for universal plug and play :) Hope this helps. Thanks
Dec 27, 2010 | Belkin (F5D7230-4) Router (587009)
PASSWORD
this is normally for wep or wap. the ipod requires you to use this technology. if your belkin is not setup for wap, please set it up. then remember your pass phrase which you will need for your ipod to connect.
Jun 19, 2010 | Belkin (F6D3230-4) Router (F6D32304)
My belkin router F5D8636-4v2(01) will only connect to the internet when the yellow cable is used the wireless light is off as is the security light also how do I put a security password onto the system...
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Jun 01, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
Installation of belkin router failed
You need to configure your router.
http://192.168.15.1
or
http://192.168.2.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Let me know if you need further assistance.
May 08, 2010 | Belkin (F5D5231-4) Router
Belkin f5d 7230-4 How can Change Password for Homepage Login?
As you are unable to access the web interface of the device your only option is to perform a factory reset of the router using the reset switch built into it as per link below:-
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/password%20f5d/r_id/166
Nov 29, 2009 | Gateway Belkin F5D7230-4 802.11g Wireless...
Can't connect to internet with my router when i use password
you can access your router with following link
http://192.168.2.1
then type user name as "admin" and password "admin" or blank or "password'
then check wi fi security and check encryption password .also check there is anyt MAC security enabled?
Jul 11, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Cannot get past a user name, password window
Take a paper-clip, and straighten it.
Turn the router off.
Look at the back of the router.
Insert the paper-clip into the small hole, and count to ten.
Turn the router on.
It will now be set to the "factory" settings,
with the "default" ID & password.
Connect to the router's web-interface, and configure the router.
May 31, 2009 | Belkin Computers & Internet
Trying to add security to belkin router
Try to access the 192.168.2.1page again. Then look for Wireless Security settings. Select WEP 64 bits as your security mode, type 10-digit # on the WEP key 1 box and save settings. The 10-digit code is your wireless security password. That's it
Jan 12, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
