Question about Pioneer GM-232 Car Audio Amplifier
Pioneer GM-232 Amp
Need instructions to wire up amp to existing stereo system, just need the installation diagram so I know what wires go where, Thanks
Pioneer GM-232 Amp - amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgThese are from the actual owners manuel-i used to have this amp also. hope these help
Posted on Dec 29, 2008
Need wiring diagram fo 1994 nissan quest gxe premium stereo
A picture requires an installation, which is what you are doing. You should invest in a vehicle specific wiring harness. The wiring colors match for the connection and said harness then plug into the factory harness. If the factory harness no longer exists then you need the wiring diagram for the vehicle. You mention the vehicle has a premium stereo, the Metra part number is 70-5510. It's for an amplified system.
Aug 11, 2012 | Nissan Vehicle Parts & Accessories
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
How do i install a pioneer radio without the instructions
Aftermarket radios have a standard wiring color set. Tell me the radio model and car year/model and I can send you the exact connection scheme.
Dec 01, 2010 | Pioneer Car Audio & Video
How to install car stereo with an amplifier and equalizer
power wire from batt fused to positive on amp .earth wire eg - to bare metal in car with bolt or screw. remote wire from amp to remote wire on back of head unit mostly blue wire it tells amp when to turn on then you need a set of rca cables to send sound from head unit to amp they go in subout if you wanna use sub or rear or front out for full sound best thing is to buy amp kit cheaper most the time and all you need there hope this helps
Oct 23, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Wiring diagram ford escort for installing nav system and stereo controls
here is some info:
Apr 13, 2009 | Ford Escort Cars & Trucks
Wiring diagram
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
May 21, 2008 | Car Audio & Video
System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
Read the following pages specifically:
Installation Primer
Head Unit
Dec 28, 2007 | Pioneer GM-5100T Car Audio Amplifier
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Car stereo installation
I had this problem as well. On my harness was a wire for connecting the factory amp. You have to connect the Automatic Antenna wire to the Factory Amp Turn On wire. Should be a blue wire to a blue wire with a white stripe.
Oct 15, 2007 | Car Audio & Video
Pioneer GM-232 Car Audio Amplifier Logo
1,374 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
