Question about Makita 3612C Router
How do you fit 6mm collet cone on new produce
Brand bew 3620x4/2 router with P-24876 bit set. Bits will not fit how do I put in 6mm collet cone - does it need brute force?
  • David Ford
    David Ford May 11, 2010
    I am not exactly sure what you are trying to do. The 3620 is a 1/4 capacity router. The bit set that you mention is not showing up on the Makita database. As far as I can remember some of the collets for the Makita routers snapped into the collet nut. If this is the case with yours all you have to is hold the nut and push the collet sideways. But again I don't know about this 6mm cone or the bit set. If you can provide more info I will try and help more.
    President:
  • 1,996 Answers
You have, I presume, already locked the spindle and loosened the collet nut with the wrench, have you not?
Once the nut is loose, you should be able to remove it by spinning it off the threads by hand. Then insert the 6 mm collet cone into the collet,
carefully thread the collet nut back onto the collet, and tighten it with the bit in place.
Sometimes bits are a snug fit, especially into a new collet. If you have some fin sandpaper you can gently chamfer the very end of the bit where you first insert it into the collet, and this may help to insert it. If you have to, push a bit.
I have noticed that some companies tend to mill the shafts of their bits a little too close to the exact tolerance, or even oversize them slightly, and this can cause frustration when inserting their bits. In exceptional circumstances, I have resorted to polishing a couple of small bit shafts with very fine (600 grit or so) emory cloth, just to allow the bit to enter the collet. I would not recommend this with a new router collet, unless you have checked the bit with a micrometer and it is oversize. Odds are you just need to break things in a little.
The force need not be brutish, but you may need to use some force, yes.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Mar 29, 2009
I have a B&D Router KW850E. It has collars and collet nut to take bits with 1/4 inch and 5/16th's shank. Can I get a collet nut and collar for 12mm or 1/2 inch?
probably not as the shanks of the router bits fit in the spindle shaft of the router which is around 1/2" dia
could always talk with manufacturer as to find an adaptor or like bit of equipment
Jan 19, 2017 | BITS Tools & Hardware - Others
I have a Ryobi R-151 router with an 8mm collet, I cannot find and router bits with 8mm shanks, is their a 6mm collet, or adaptor available for this model? Regards Pete
There are 8mm to 6mm adapter sleeves available. If you take the collet along to a power tool store they may be able to supply you with a suitable 6mm collet. I can't find what type of collet is in the router, but I'm betting it is a ER-11 type in that size range.
https://www.maritool.com/images/ER11-Collet-1.jpg
Nov 23, 2016 | Ryobi Tools & Hardware - Others
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
Dec 28, 2012 | Bosch 1617EVS 2 Router
I have a brand new Ryobi router model ERT241200. Am I supposed to insert the 1/4'' collet into the cavity where the collet nut is, then insert the bit into the collet and tighten the collet nut? I thought...
Do you have the collet upside down? It should fit in nicely and the lock nut fit over the top, no problem, If it doesn't, something is wrong. They only make 2 sizes of collets for router bits, 1/4 and 1/2 , if they get their parts from somebody who makes just collets, you could have easily gotten a different size in there. See if a router bit will fit the hole, then go to the store where you bought the router and ask them to try it in your router and see if it fits, they might have collets on the shelf. Check it out.
Jun 03, 2010 | Ryobi Tools & Hardware - Others
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Apr 20, 2010 | Freud FT2000E 3 Router
Ive got a kenzo router and the router bits do not fit . ive got quarter inche cutters and when the collet is done up tight the cuters are still not tight. its not a half inch router as ive measured it. any...
Your router bits must have a 6mm shaft, whereas your router with the collet closes down on a 1/4" or 6.4mm shaft. You will need to get a metric collet for your router spindle, or get a new set of 1/4" bits
Sep 28, 2009 | Freud FT2000E 3 Router
The router bits will not fit in the collet. When the collet snaps into the collet nut the bit does not fit.
The collet is loosely screwed on, correct?
Is it close, or 1/4" off. You may need an adapter for different sized bits.
I have noticed, particularly with Freud bits, that they seem a bit oversized. Try putting the bit in the collet before you insert the collet into the router.
If you're very careful, you can use fine emory cloth (like 400 grit or higher) to polish the bit by cutting a long strip and clamping the bit in a vice, then gently polish the shank a little to allow it to fit into the collet. Pull back and forth on the ends of the sandpaper like you were buffing shoes, but I would only recommend this if you can use a micrometer to check the shank and it is in fact oversize.
You could create a dangerous situation if you polish too much and the bit is not held securely in the collet and flies out when the router is under load.
Another technique is to sand a slight chamfer on the end of the bit to help it slide into the collet.
Or return it and try another brand.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 15, 2009 | Freud FT2000E 3 Router
Slipping Bits
Any time I have ever come across this problem over the years the cause of it is a damaged collet due to overtightening. The solution is to replace the cone shaped piece ( the collet ) and take care not to overtighten in the future.
Sep 16, 2008 | Porter Cable 1 - 3/4" Hpfb Router with...
Makita 3612C Router Logo
616 people viewed this question
Top Makita Tools & Hardware - Others Experts
buzz flewhart
buzz flewhart
John Trevino
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
