Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Bad color blue green bad pic tried adj covergence no luck
Phillips mod 50pp920217
  • david_elstun Dec 29, 2008
    Thanks, If I need the part where can I get it , how much? Is stk392-120 the part #?
  • 4,234 Answers
The problem is either poor solder connections on the convergence ICs ore defective ICs. If you can solder, you can fix this yourself. Be aware however, of dangerous high voltages that are present even with the set unplugged. The ICs are STK392-120s and should be attached to a large heatsink. Try resoldering the pins first. If that fails to resolve the problem, replace the ICs.
Dan
Posted on Dec 29, 2008
  • ABRsvcs Dec 29, 2008
    You can order the part from Tritronicsinc.com for somewhere around $25. There are other suppliers as well. Any electronics parts supplier should be able to supply these. The STK number is the generic part number. The specific Philips number I don't have at the moment, but getting the part from Philips will just cost more.
    Dan
How do I calibrate the color or covergence....it seems the pic has too much blue in the color..
using your remote and menu settings you should be able to find it however if it is unable to be fixed call up customer support.
Mar 06, 2011 | JVC AV-56WP74 56" Rear Projection...
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
Halo around blue, extremely bad when watching
The CRT coolant in the Blue CRT needs replacement. The green will soon follow. Very common problem with phillips. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant and the CD with instructions.
May 10, 2010 | Philips 60PP9363 60" Rear Projection...
How can you tell if one of the bulbs is burnt?
That color won't work good. On RPTVs, Red bad = blue-green pic; Green bad = purple pic; blue bad = yellow pic.
May 02, 2010 | RCA HD52W58 52" TV
Bad color; everyone and everything is very orange
contact the store you bought it from. They will help you or refund you
Mar 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a phillips 50pp920217 tv and the problem is that one lens or lamp its burned. AT the bottom the pictures has a wave and shadow of color red.
Sounds like some of the coolant has been lost. Refill with the same glycol based coolant as original.
see here:
http://www.google.com/url?q=http://www.mcmelectronics.com/browse/CRT%2520Coolant/3830007&ei=VktsSr2wGcKFtgfvqYWbAQ&sa=X&oi=spellmeleon_result&resnum=2&ct=result&usg=AFQjCNHIbkkEwW3p8jUKnwgc30LApH-Xww
Jul 26, 2009 | Philips 50P8341 50" Rear Projection...
Mitsubishi 55 inch Rear Projection w/ Green tint
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Jun 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Covergence problem
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | JVC AV-56WP30 56" Rear Projection...
1994 RCA P52753 Rear Projection
Sounds like the screen asy has failed causing the color to change from black and white,turn your color all the way down and see it the picture is green,blue,or red,if so the asy is bad or the tubes are getting alittle weak,the asy is in front of the set behind the speaker grill,there is a access panel to remove and the asy has 6 controls to adj.,only move the ones that are marked screens below them,this asy is black and is only 4 inches square,do not move any adj. on the tubes
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA ATC113AA.F20TF20 G2 Problem
adusting these stuffs needs a special equipment like the color pattern generator. u cannot just adjust this manually. try to inspect the crt circuit board see if there is an open resistor there. u have a luminance problem
Jan 04, 2007 | Sony KV-35S45 35" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
