Question about Hoover UltraCare HC6 150M Front Load Washer
Tripping out. Just as the machine begins to fill up the electric trips out. With the motor unplugged the machine will not trip. It may well be the motor, but after several attempts to reset the trip switch, the machine will run a full cycle. Could it just be the brushes on their way out or should i just replace the motor.
  • Hoover Master
  • 3,463 Answers
Sounds like a brush prob to me.
Remove rear panel and remove motor to check carbs.
Replace if there is less than 2or 3mm left.
If it still trips after replacing carbs, then motor faulty.
Plz rate this solution.
Thanks.
Posted on Dec 31, 2008
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Beko wm5121w 5 kg keeps cutting out the electrics can open the door machine starts to fill and eveything cuts out
With the machine unplugged, try disconnecting the heater and then turn the machine back on. If it is still tripping the electrics reconnect the heater and disconnect the motor, then turn on again. Likely one of those is causing the fault
Mar 12, 2014 | Washing Machines
My hotpoint washing machine wdf740 washer/dryer keeps tripping the electrics when it starts a program? If there is no program running, its fine but as soon as i hit start and water fills up the drum, the...
Could be a faulty motor or heater element, you need to isolate the heater and try it again, if it still trips, then I would suspect the motor is faulty, try unplugging the motor at the rear of the washer, and try it again, I'm afraid it is a process of elmination.
Jan 24, 2011 | Hotpoint Aquarius WD640 Front Load...
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Jun 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Tripping the breaker
How far into the cycle does it trip the breaker?Does the motor run then trip it?Is it at the end of the cycle when it goes to a dry cycle?Does it trip in the beginning when it fill's up with water?
Mar 19, 2009 | Dishwashers
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hoover UltraCare HC6 150M Front Load Washer Logo
285 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
