Question about JVC AV-48WP30 48" Rear Projection Television
Convergence no good on lower corners and upper screen
I got a convergence problem on my JVC 48wp90. The red would not adjust vertically, so I replaced my ICs and all the corresponding 1 watt resistors. Now my convergence adjusts, but doesn't completely line up. In the screen with the crosses, 123 456 789 positions 4,5,6,8 line up great; position 2 isn't bad either. But 1,3,7, and 9 don't line up. 1 and 3 bend up towards the top of the screen, and 7 and 9 bend down. In the convergence lineup on the grid screen, the red line across the top is wavy and really messed up in the top right corner of the screen? Any suggestions? thanks.
  • 1 more comment
  • Jamie Bur Jun 26, 2007
    I reordered and re-replaced the ICs and resistors. I put in the upgraded stks. I can adjust the convergence and save the setting, but it won't hold well. The problem is still the wave in the red at the top. Here's a screen shot:
    Here's a picture of the convergence from the TV menu:
  • Anonymous Dec 09, 2007
    convergence
  • 3 Answers
It looks like, to me, that you have to recalibrate the convergence ROM in your TV. I have a JVC 48WP34 and it was doing the same thing. I thought I was saving my settings (Writing to ROM) but I was doing it wrong. It took me a while to figure out how to correctly get the lines straight then save them. If I remember correctly, once you get the lines straight, you have to press 2 buttons at the same time to get it to write to the ROM. Anyway, if you can get the grids to line up properly and spaced properly, you shouldn't need to go to the standard convergence screen through the menu. You should be able to push that convergence button inside your TV near the chips you replaced, use the remote to line up the lines (either the 7 8 9 buttons or 100+ 0 return+ buttons change between colors and 2 5 4 6 adjust up down left right). I think I hit the select button then I hit the select and enter button at the same time to get it to save. Every time I tried to save (before trying the combo I just mentioned) then go into the standard convergence screen in the TV menu, it would undo the settings I did in the other convergence screen. So once I tried the save combo I mentioned a sec ago, I haven't tried making any changes in the standard convergence menu. I hope this helps for you.
Posted on Aug 13, 2008
  • 203 Answers
What you're actually seeing is what the TV looks like without any convergence. I would also suggest replacing them with the 392-150 as they are better at handling the current. If the new STKs don't fix the issue then you may have another issue on the convergence module
Posted on Jun 09, 2007
  • 934 Answers
I'm assuming you used STK392-110 for a replacement. You could use STK392-150 for greater reliability and don't forget a good heat sink compound. (VERY IMPORTANT). What it sounds like is something even the best of techs battle. You probably didn't buy original Sanyo STK's but instead got a couple of the JApan knock-offs. Might I suggest you carefully replace them again and this time order them from B&D Electronics, Bdent.com on the net. You are assured of getting quality OEM replacements that way... We've had a bad batch that purchasing ordered quite some time ago and 2 out of the 14 ordered worked.. The rest were DOA (dead on arrival). Good Luck Bill
Posted on Jun 08, 2007
I CANT ADJUST THE RED VERTICAL LINES ON MY JVC REAR PROJECTION TV. i HAVE DONE CONVERGENCE AND MANUALLY ADJUSTED THE RED LINES HORIZONTALLY, BUT NO LUCK WHAT CONTROLS TO USE VERTICALLY
If it will not adjust up or down or left and right the convergence chips need to be replaced.
See attached photos of board that is in your set:
This can be a do it yourself repair and the parts do not cost a fortune.
Can I help?
SD TECH
Oct 16, 2011 | JVC AV-48WP30 48" Rear Projection...
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
Upper corner of picture looks like 3D. picture on upper corner looks like it is off vertical with this happening. What do you do to fix this Hitachi 57F500 model?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 21, 2011 | Hitachi 57F500 57" Rear Projection...
I have a double picture and the red apears to be
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 07, 2009 | JVC AV-56WP74 56" Rear Projection...
My set is 10 yrs old. In the upper left and lower
Try adjusting the convergence. If it won't move see below- red IC in particular
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
Oct 18, 2009 | Sony KP-43HT20 43" Rear Projection...
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Bowed flickering green screen, black on bottom
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 25, 2009 | JVC AV-48WP30 48" Rear Projection...
Red Convergence on JVC AV- 65WP74
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Oct 12, 2007 | JVC AV-65WP74 Rear Projection Television
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Aug 22, 2007 | JVC AV-27320 27" TV
Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Jul 02, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
310 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
