I want to buy a memory card for my casio 7.2 mega ex-z750
SOURCE: Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
SOURCE: Casio Exilim won't turn on when memory card is inserted
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
SOURCE: Lost cable to connect Casio exilim EX-Z77 to
you need a usb-mini b cable can get it off ebay real cheap...
http://cgi.ebay.com/USB-A-to-Mini-B-5-Pin-Data-Cable-Adapter-Male-M-MP3-DC_W0QQitemZ250447346226QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item3a4fd33a32&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1205|293%3A1|294%3A50
SOURCE: just got me a casio exilim zoom ex z80 and i cant
Format the card using a card reader on computer and select file system as FAT
SOURCE: casio exilim ex-z20 keeps saying memory card
Move the slide switch on the side of the card. Then, go into the camera menu and find "reset"...follow the on-screen instructions.
