Question about HP PSC 1510 All-In-One InkJet Printer
Error message cant install the printer hp series 1500 wen try to click on the set file this message comes- insert al in one lebeled microse r
    President:
  • 8,637 Answers
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Printer HP Photosmart C5180 Series cannot be contacted over the network
Check with HP for a Windows 7 driver for the printer. HP Ink Jets require proper drivers to work correctly. Once you have downloaded and installed the drivers try connecting again.
If you have installed the drivers and Windows 7 still refuses to "talk" to the printer, you may have to adjust your advanced network settings as well. Open up the Network and Sharing center, click on advanced sharing settings and make sure file and printer sharing is turned on. Also check "File Sharing Connections" and enable file sharing for devices that use 40 or 56 bit encryption.
If that fails to work you may need to speak with HP support for further assistance.
Feb 23, 2012 | HP Photosmart C5180 All-In-One InkJet...
Hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
Oct 19, 2011 | Office Equipment & Supplies
The printer is displaying error: B0605 on the screen
HI............
Issue Description: Print cannot boot up into ready state with an error message shown on printer control panel. The error messages include ERROR: B0601/ B0602/ B0603/ B0604/ B0605. Root Cause: Firmware crashes. Note: Inappropriate behavior may cause firmware crash. For example, a printer is turned off when critical firmware update is undergoing. Solution: Firmware Update Utility.
There are two use cases when encountering the issue: Instructions for Use case 1: driver is previously installed on PC
  1. Place printer in bootcode mode.
    1. Hold down the Cancel and OK buttons.
    2. Power on printer.
    3. Continue to hold down buttons until control panel dislpays Hewlett- Packard on the first line and Bootcode on the second line.
  2. c01688132.jpg Please observe the printer control panel and verify Downloading Update Data is displayed on control panel followed by Programming App Flash; please wait for upgrade utility to finish. Printer would be restarted automatically and the control panel display would show Ready .
Then the firmware is now successfully recovered. Instructions for use case 2: driver is NOT previously installed
    1. Insert printer installation CD.
    2. In Windows OS, please go to Start , Settings , Printers and Faxes .
    3. Click Add a printer to start Add Printer Wizard as shown blow and click on Next button. c01688133.jpg
    4. Check Local printer attached to this computer box; uncheck Automatically detect and Install my Plug and Play printer box and click on Next button. c01688134.jpg
    5. Select FILE:(Print to File) in the Use the following port: dropdown list and click on Next button. c01688135.jpg
    7. Browse to the CD drive in which the printer installation CD is inserted previously and click OK button. c01688137.jpg c01688138.jpg
    8. Highlight the HP LaserJet P2050 Series PCL 6 found in the printer installation CD and click on Next button. c01688138.jpg
    9. Specify the Printer name and click on Next button.
    10. Select No for Do you want to print a test page? and click on Next . c01688139.jpg
    11. Click the Finish button and allow driver to install as shown below. c01688140.jpg
    12. Verify printer is listed in Printer and Faxes window as shown below: c01688141.jpg
  1. Place P2055 in boot code mode:
    3. Continue to hold down buttons until control panel dislpays Hewlett-Packard on the first line and Bootcode on the second line Printer is now in bootcode mode.
  2. In the Printer and Faxes window, right click on the HP LaserJet P2050 Series PCL6 icon and select Properties .
  3. Click the Ports tab and view the USB ports as shown below.
    NOTE: If more than one (USB001) please take note of all listed ports, as other installed printers may have USB ports (USB002, USB003, etc). c01688142.jpg
  4. Close Properties window.
  5. Plug in USB cable from to PC
  6. The Found New Hardware Wizard will pop up, and tje printer USB enumeration will happen.
  7. Open printer properties and select Ports tab again.
  8. In ports tab, tick the correct port that the HP LaserJet P2050 series printer is enumerated on and click OK . c01688143.jpg
  9. Click Cancel on Found New Hardware wizard window.
    NOTE: Not the driver is installed and it is pointed to correct USB port.
  10. Run HP LJ P2055 Firmware Update Utility.
Sep 21, 2011 | Computers & Internet
Hp deskjet 3650 printer was working fine and now it will not print. I get a message saying The file 'hpzimc09.dll' on hp cd is needed. Also when I go to my control panel and click on printers and faxes...
delete both and re install.
If you are missing a dll then you may have had a virus that infected some files, and these may have been removed with a scan.
If you dont have your driver disc, download your software from HP / support http://h10025.www1.hp.com/ewfrf/wc/product?product=304535&lc=en&cc=uk&dlc=en&lang=en&cc=uk
Sep 30, 2010 | HP DeskJet 3650 InkJet Printer
I downloaded hp psc 1315 all in one printer software but while installing i am getting error message so that unable ot contiune the installation also autometically it is getting uninstalled. please give...
find software from different web sit .sound like the copy you have is missing some of the set up files. Good luck Try windows web site for drivers they carry al lot .I use all the time.
Aug 12, 2010 | HP PSC 1315 All-In-One InkJet Printer
Usb error
To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Jul 23, 2010 | HP LaserJet P2015 Printer
I can not scan from the printer 1500 series. I
Make sure that the HP drivers are installed on your computer. Try the following steps:
1. Click the start icon then click All Programs, and then click Windows Photo Gallery .
2. Click File, and then click Import From Camera or Scanner .
3. Click Import , and then click Scan .
Hope this helps!
Jan 29, 2010 | HP PSC 1510 All-In-One InkJet Printer
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
Sep 07, 2009 | Office Equipment & Supplies
HP J6480 error message insert 'solution center disk'
When you get this error message again, insert the installation disc you used for the printer set-up. Then, click on "browse" and go to D:\Setup\SolutionCenter (D: denotes the drive letter of your DVD drive), and you'll find solutioncenter.msi there. Select it, and then click on "OK" ...it should then repair the installation and the issue should be resolved.
Dec 12, 2008 | HP OfficeJet D135 All-In-One InkJet...
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
Jun 09, 2008 | HP LaserJet 1018 Printer
HP PSC 1510 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
