Question about Minolta X-370S 35mm SLR Camera
Minolta X-370 Spot driving me nuts!
I'm hoping that someone out there can instruct me on how to clean a Minolta X-370. The camera works great and takes great pictures, but there is a spot inside it that is driving me nuts. I have cleaned the mirrors which did no good at all. I'm guessing this may be in the viewfinder area. It's just right off the center of the picture and it's very irritating because it's right in my line of sight. Any suggestions would be greatly appreciated
    Scholar:
  • 95 Answers
If its inside the viewfinder, then you'll really need to take it in for a repair, but bear in mind, that will require disassembly and that will likely run you $75-$100, which is more than a used X370 goes for on eBay.
One thing I would check is the underside of the focussing screen as maybe it is on there. Remove the lens and then look thru the viewfinder. If you still see the spot, then its in the body and not in the lens.
Look inside at the underside of the prism - thats where the focussing screen is. Do not touch the screen with any cleaning fluid or your finger. instead, grab something fairly stiff but pliable, like the straw on the edge of a dust blower. and gently rub the general area on the screen where the spot might be. Then blow the area with air to clean it all up. Look thru the viewfinder again and see if that got it.
Its pretty rare for dust to get inside the viewfinders unless they had previously been open for a repair, so theres a good chance its stuck to the focussing screen. Don't touch it with solution or your finger though as the screen can be damaged easily.
Posted on Dec 30, 2008
How does the back of the camera open to load film?
Unwind the film rewind crank and lift up.
If you need a manual, you can download one from
http://butkus.org/chinon/minolta/minolta_x-370/minolta_x-370.htm
Sep 20, 2011 | Minolta X-370S 35mm SLR Camera
The film advance lever is stuck on my minolta
Here are the most likely:
A. Lever will not move on some models if the shutter is already cocked. If the shutter is cocked, and will not release with new batteries INSERTED CORRECTLY, then the most likely is this...
Two capacitors in these Minoltas die over time. If you are handy at such things, you can buy the caps, remove top and bottom covers, remove the dead caps and solder in the new ones. Don't Panic.
You can find instructions on the web for this well known issue, and you can also opt to send it to a camera repair place. Garrys camera repair in Niles, ILL does it for about $58 incl return shipping. He will also clean, lube and adjust it for ya. Something they all need eventually.
Oct 04, 2009 | Minolta X-370S 35mm SLR Camera
How do you open a minolta x-370 camera?
Hi - You can download the manual by clicking the link underlined in blue below:
minolta x-370
See page 13:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 24, 2008 | Cameras
Film advance
It usually is the shutter not firing therefore jamming the advance. Try www.flcamerarepair.com They do not charge for ests.
Jun 28, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Compatibility of vivitar lens with Minolta x370
Minolta X 370 is not an auto focus camera so provided you are willing to use the Vivitar lens in manual AND provided the lens has minolta mount , you will be able to use it.
Sep 04, 2007 | Cameras
Minolta X-370S 35mm SLR Camera Logo
211 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
