Question about Kenmore Elite HE4 Electric Dryer
Water leak from Kenmore elite
Water leaks out during drain cycle. No leak found at hose fittings. Is there anything I can look for inside the machine? Or juyst call the repair man?
  • Kenmore Master
  • 19,396 Answers
If the leaks happens during drain cycle, this is usually because of a leak on the drain pump hose, or because of a faulty drain pump that is leaking.
As the appliance must be taken apart and the pump may need replacement, it is better to call a repairman to do the job.
Check that leak is not from drain hose, from water supply hoses, or from gasket first.
Posted on Dec 29, 2008
How do i get to the main drain and pump on a kenmore elite front load washer
You will need a few towels. There is a cartridge like filter located on the front lo2er left corner of all current front load washers for cl3aning purposes. Remove or open the access panel plate and begin unscrewing the cartridge. After about 3 full turns it will begin to leak water. If you have a elevation base with a drawer place towels inside there to soak up water that leaks out. Once drained unscrew and pull straight out to clean the lower filter. There is another place to clean out just inside the drum on the front just under and behind the door seal
Jan 03, 2015 | Kenmore 4.0 cu. ft. Steam Front-Load...
Want to find out why my washing machine is leaking water
It is most likely the water pump on the washing machine. Check the hot and cold hose and make sure there are round gaskets on the inside of them and that they are tight on the hot and cold valves.
Also check the drain hose that it doesn't have any holes in it and that the hose is far enough down into the drain . If all that's ok, it's your water pump.
Jun 26, 2013 | Sears Kenmore Elite Electric Dryer 69278
My whirlpool duet sport is leaking from the front underneath. Not from the door. When the wash cycle starts it starts spraying water out the bottom. Does not do it when it drains.
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Oct 11, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Kenmore washing machine not empyting all the way during the rinse cycle? the machine washes fine but not empyting all the water during the rinse cycle?
Does it go into high speed spin? If it does and there is still water than check to see if the filter or hoses are clogged. The hoses the run from your basket to the pump and the drain hose too. A washer is only given so much time to drain all the water. Most of the time the filter or coin trap hose is clogged. If everything is clear u may have a weak pump.
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 09, 2010 | Kenmore 67082 Electric Dryer
Kenmore Elite HE4 won't start
Top 10 front-load washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisy,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nesessary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Over-sudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Feb 06, 2010 | Kenmore Elite HE4 Electric Dryer
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE5 Dryer beeps while running
Aug 14, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Washer leaks water
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Aug 08, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite 4t
This what to check for F/H code from repair manual.
If the water is coming into machine, make sure drain hose is only sticking into drain pipe about 6 inches. Post back if you have any questions.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then
valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has
detected 10.5 gallons of water passing through it, but has not detected the pressure
switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Nov 07, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
175 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
