Question about Olympus Camedia C-770 Digital Camera
Computer with XP running program dies when usb connected to c-770
Computer automatically shuts down and will not re-start until c-770 is unplugged......please help! do I need to reset the c-770? or is there something wrong with my PC or camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Nov 20, 2012
SOURCE: Vista not recognising Olympus camera on USB connection
I just spoke to Olympus Tech Support.
You have to download Olympus Master 2. (Their program is no longer called Camedia Master.)
http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp
At their main site, search for olympus master 2.
Posted on Apr 02, 2008
SOURCE: Olympus 2G xd M card with pictures - error message "clean card" or format
I also have had this problem.. I rang Olympus & they sent me a Digital Image Recovery Freeware.. Im currently trying that. They told me that for some reason wen we put our XD cards in our card reader it puts a file on the card, which can sometime corrupt the card. If you cant get the pic off your card using a recovery program, you can send away & get it professionally done..(probably at a cost). The only way to get rid of the error is to format your card again try to remember to upload pics with your cable rather than the reader.
(Fingers crossed I can get my images from this software)
Posted on Jun 05, 2008
SOURCE: Olympus C-3000Z and Vista, can't unload
i have an olympus c-3000 more don"t instalaction automatical to windows i dont have the softwear for instalaction : cd ok
Posted on Nov 02, 2008
  • 15 Answers
SOURCE: Computer not recognizing Camera
Are you always using the same USB-port on your PC? If yes try to use another USB-port.
If the above solution will not work try to re-install the camera drivers.
Posted on Nov 30, 2008
  • 11967 Answers
SOURCE: How do I download pictures from my Olympus camera
Use a separate card reader to download your pictures.
Posted on Aug 28, 2009
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Tip
Automatically Close Programs at Shutdown
When you shut down Windows, if you have any programs running you'll get a message box warning you that a program is still running. You then have to close the program and tell XP again to shut down. It's a fairly pointless warning—better yet would be if XP automatically killed the programs without issuing the warning. That way, you wouldn't get error messages and wouldn't have to close each individual application before shutting down your computer.
To have XP automatically close programs at shutdown, run the Registry Editor and go to HKEY_CURRENT_USER\Control Panel\Desktop. Edit the AutoEndTasks key so that is has a value of 1. If the key doesn't exist, create it as a DWORD value and give it the value of 1. To disable it, either delete the key, or set the value to 0.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Olympus stylus 770 cable has problem transferring photos to computer. This only started month ago. Once connected to computer, camera screens reads 'one moment' but never actually connects to computer....
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 24, 2010 | Olympus Stylus 770 SW Digital Camera
Diamge Scan II, Error = 5 Windows 2000, Error = 1 on Windows XP
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 14, 2009 | Minolta Dimage Scan Dual II Film Scanner
Remote access to dial-up connected computer
https://secure.logmein.com/home.asp?lang=en
Try this.Set it like after reboot it automatically starts.
Once it comes up you will be able to connect again.
Please rate me if you like my solution.
Mar 12, 2009 | Microsoft Windows XP Professional Upgrade...
Software runs until I power down at next power up software dies.
I would suggest purchasing the version of the Mavis Beacon Teaches Typing v 1.5. It's compatible with Windows XP. I've also looked at the software description and you are able to select the age group of the typing test.
However, if some reason you have to continue with the same version. What error message do you recieve?
Thank You, Raphael
Jan 21, 2009 | Mindscape Mavis Beacon Typing for Kids...
PC shuts down when c-770 is conected via USB
Dec 29, 2008 | Olympus Camedia C-770 Digital Camera
PC SHUTS DOWN MONITOR AND FAN
Hi Brandy19960,
Thanks for the posting in FIXYA.
Please do the following steps:
Step – 1
Right-click on My Computer, open Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” Uncheck the box in front of “Automatically restart.”
Step - 2
To change the setting, click Start --> Run--> type GPEDIT.MSC, click OK.
Drill down to Computer Configuration | Windows Settings | Security Settings | Local Policies | Security Options.
In the right pane, find “Shutdown: Clear Virtual Memory Pagefile.”
NOTE: Since someone actually has to have set this policy, the problem will be pretty rare, but is worth mentioning. However, Forum participant “roadrunner” reported that the personal security app Privacy Eraser automatically enables “Clear virtual memory pagefile,” and, therefore, may be the cause of a slow shutdown.
Step - 3
When Windows XP won’t powerdown automatically, the APM/NT Legacy Power Node may not be enabled. To enable this, right-click on the My Computer icon, click Properties | Hardware | Device Manager | View. Check the box labeled “Show Hidden Devices.” If it’s available on your computer, there will be a red X on the APM/NT Legacy Node. Try enabling it and see if this resolves the powerdown problem (Tip from Terri Stratton). Or, to check the other side of the APM/ACPI coin, open the Power Options applet in Control Panel. If there is an APM tab, make sure the “Enable Advanced Power Management Support” box is checked.
Step - 4
Try a Shutdown shortcut -
For a shortcut to RESTART Windows XP:
SHUTDOWN -r -t 01
For a shortcut to SHUT DOWN Windows XP:
SHUTDOWN -s -t 01
Step 5
WORK-AROUND: Disable power management for your USB hub: Open Device Manager (click Start, click Run, type DEVMGMT.MSC, click OK). Double-click to expand Universal Serial Bus Controllers. Double-click USB Root Hub. Click Power Management. Uncheck the box “Allow the computer to turn off this device to save power.” OK your way out
Step – 6
Click on the Start button.
Select Run from the menu.
In the run dialog box type “msconfig”.
Click OK.
Once in the msconfig utility select the startup tab. In the startup tab you will see several programs listed with a checkbox beside it. If there is a check mark beside the application listed, the application will startup when your computer starts up.
Regards
ELLIN
Sep 13, 2008 | Microsoft Windows XP Home Edition
Operation of computer while connected to F380 .
Hai
I understand that your Isue is "After installing the HP All-in-One software, the computer stops responding during start up when the All-in-One is connected and turned on. The computer will start correctly if the All-in-One is not connected or is turned off."
SOLUTION:
This problem can be resolved by changing the "USB Emulation" in the Computer BIOS settings.
If you are using a DELL Computer just follow my instruction below.
Caution:
If you are using a USB keyboard, do not disable “USB Emulation”, “USB Keyboard Support”, or “USB Legacy Support”. If the settings must be disabled, use a PS/2 keyboard
Changing the BIOS on a Dell Dimension computer
Follow the steps below to turn off the ability to boot from USB devices but still support a USB keyboard while starting. Contact Dell for assistance if necessary.
  1. Shut down the computer.
  2. Unplug all USB devices other than a keyboard.
  3. Start the computer. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press the Down Arrow key to highlight Integrated Devices (Legacy Select Options).
  5. Press the Enter key.
  6. Press the Down Arrow key to highlight USB Emulation .
  7. Press the Space Bar until the “ No BOOT ” option displays.
  8. Press the Esc key twice to go to the Exit menu.
  9. Plug the USB devices back in.
  10. Ensure that “ Save Changes and Exit ” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Changing the BIOS on a Dell Laptop PC.
  1. Shut down the portable.
  2. Unplug all USB devices including USB keyboards.
  3. Start the laptop. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press and hold the ALT key while tapping the P key until a screen displays that includes the words “ USB Emulation ”.
  5. Press the Down Arrow key to highlight “USB Emulation”.
  6. Press the Right Arrow key until the “Disabled” option displays.
  7. Press the Esc key once to go to the Exit menu.
  8. Plug the USB devices back in.
  9. Ensure that “Save Changes and Exit” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Change the BIOS on computers from manufacturers other than Dell If you do not have a Dell computer, contact the computer manufacturer for assistance. If the manufacturer does not know how to disable starting from USB devices, they may be able to change the order (boot order) of the disks the BIOS uses to start the computer. Move the bootable USB devices selection lower on the list than the computer hard disk drive. If you have any further queries or if the problem still persists, reply me. Thanks Riz (jack_36623@yahoo.com)
May 20, 2008 | HP DeskJet F380 All-In-One Printer
Nokia n770 white screen of death!
More than likely re-flashing your 770 with a fresh copy of it's operating system may fix your problem. This is a Cut/Paste from Nokia's site. http://europe.nokia.com/A4144790
  1. Download the Nokia Internet Tablet Software Update Wizard and save it to your computer. http://nds1.nokia.com/files/support/global/phones/software/Nokia_Internet_Tablet_Software_Update_Wizard.exe
  2. Install the Nokia Internet Tablet Software Update Wizard by running Nokia_Internet_Tablet_Software_Update_Wizard.exe. This will install the update wizard and the Nokia USB cable driver if needed.
  3. To access the Nokia Internet Tablet Software Update Wizard on your computer, open the Start menu and select Programs > Nokia > Nokia Internet Tablet Software Update Wizard > Nokia Internet Tablet Software Update Wizard.
  4. Follow the instructions on screen to complete the software update.
Please note, you must have a USB cable to connect your 770 to the computer and the 770 must be fully charged and connected to the charger before you begin.
Hope this helps. It fixed a lot of problems I was having with mine.
Jan 27, 2008 | Nokia N770 INTERNET TABLET LINUX OS...
Olympus Camedia C-770 Digital Camera Logo
26 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
