My laptop won't shut down properly!
My new laptop wont shut down properly. I log off or shut the laptop down but, this part works fine and all the programs close, however, then the logging off page comes up but no matter how long i leave it it wont shut down completely which means that i have to turn it off without it properly shutting down. How do i fix this? Someone please help!
  • Anonymous Jan 11, 2009
    same props exactly......
    Problem Solver:
  • 16 Answers
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Posted on Dec 29, 2008
Why wont my laptop log off even if I shut it down manualy
You will need to remove all power. This includes the battery. Then when you start up your system will report it shut down incorrectly. Select to start normally and as soon as the system has settled down properly shut it down again.
This fault is caused by a memory error when unloading on of the systems drivers. The above process will reset the driver(s) so that they load correctly next time you switch on...BUT YOU MUST REMOVE ALL POWER FIRST for it to shut down as it is stuck in that unloading loop.
Sep 18, 2014 | Dell Inspiron Computers & Internet
Comcast.net e-mail sign-in on Sony Vaio laptop is not working. will keep on bouncing back to 'log inpage'. my password and account work on any other computer. thanks
Go into system, find the wi-fi adapter and open it up. Choose uninstall and click on it. If windows asks you if you want to remove the software from the hard drive say no. Wait for uninstall to complete than shut down the computer, shut down, not reboot. Wait a couple of minutes than turn it back on, sign in and let windows find and reinstall the driver. It now should work. 9 times out of 10 this corrects this issue.
Dec 22, 2013 | Computers & Internet
Help with laptop
Reinstall windows, or Factory reset...
May 14, 2013 | Gateway NE56R10u Laptop Intel Celeron...
My toshiba laptop keyboard is locked. Oddly, it's not locked log IN to windows 7, but it won't let me type once I'm logged in. I'ts a p755. It seems to work fine in linux as well.
Its definitely an issue with some programs which loads only after windows is completely loaded. It maybe the drivers acting up or some other malicious programs which is trying to hinder with the functioning of your keyboard. Try uninstalling the keyboard drivers and restart the computer. Let me know how that goes.
Sep 21, 2017 | Computers & Internet
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Blue screen
Yes normally if you don't shut down your system properly you get this message, Solution : Log on to save mode and backdate your computer to the day before you got this message. If it doesn't work, you are gonna need to reinstall your O.S.
Feb 07, 2012 | Dell Inspiron 710m Notebook
It wont charge im holding it right nw hoping it wont shut down help fast
If your laptop won't hold a charge and you need to hod the connection in order for it to stay on, you may have a power jack issue. The power jack on the laptop may have been moved around from moving the laptop while connected or wiggling around the connection, and needs to be re-soldered back on the motherboard.
Also, just before taking that step, try using a different or brand new charger. Sometimes the pin inside a charger might be bent or broken, therefore not making a proper connection with the power jack.
Hope this helps.
Jun 25, 2011 | Computers & Internet
I just shut down and it is just saying "logging off" and it has not been about 20 minutes???? Is it stuck, what do I do, it will not do anything?
start ur laptop & press F8 BUTTON for 2 minutes only. it will come back in working condition before one day. but those work u r working on laptop, it will be lossed. if interested then do it.
thanks,
sanjeev,
+919876388918
Aug 18, 2009 | Computers & Internet
Will not log off or shut down properly
sounds to me like a spyware problem.... i recommend downloading a spyware scanner and scanning your computer for threats
May 28, 2009 | Toshiba Satellite P300D-ST3711 Notebook
Computers & Internet Logo
398 people viewed this question
David Payne
David Payne
