Question about Plumbing
All of a sudden can not get hot water from my Grohe Ladylux plus
Receiving hot water in other faucets but not the kitchen, which had been working earlier in the day.
    Novelist:
  • 148 Answers
I aasume this is single handle
You will need to remove the handle(usually hex screw under lever or bak side covered with small erasure size button
turn water (hot and cold) off under sink
remove the handle
take an adjustible wrench and remove the cartridge it is keyed
so ou can put it back roperly inspect the cartridge for any obstructions
go under sink and slowly turn hot water on and observe if water is coming out of faucet manifold
if water is coming out ok you may have a bad cartridge or had a blockage reinstall cartridge(after youturned water off
turn hot and cold water on under sink and try again
if it works great if not I suggest you take artridge out and replace
Posted on Dec 30, 2008
I want rotate my Grohe ladylux kitchen faucet. The handle is on the left and I want to rotate to the right side. How do I do it? Thank you John
You will presumably be pushing the faucet handle away from you instead of pulling it forward? If you don't like it, you can always put it back.
Turn off the water.
Release the water in the faucet. If you have a faucet in a room on a floor below, open that to drain the water.
From underneath the unit, back off the nut that is gripping the worktop. Slacken off the hot and cold supply pipes. I am hoping you have braided flexible hoses, or you can't do this job very easily.
Spin the faucet 180'.
Retighten the hold and cold supply pipes.
Retighten the holding nut.
Turn on the water and open the faucet.
Check for leaks.
There is an installation video here.
https://www.youtube.com/watch?v=sQgi0CMAxYM
and some further information and diagrams here.
Removing Grohe LadyLux Caf 33 755 Faucet Handle
Jan 02, 2016 | Grohe Plumbing
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I've removed the screw but can't get the handle off my Grohe Ladylux single handle faucet.
many times the handles will corrode on tightly....
A sharp rap from a rubber mallet will sometimes work, but most of the time you will ruin the faucet when getting the handle off...
heatman101
Jul 09, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
I have a Grohe Ladylux plus kitchen faucet very similar to this one, when I turn the water on there is a slight clunk and the water flow decreases. I am assuming I need a new valve but I havent' been able...
Before you start taking the whole faucet apart try taking the airiator or head of the end of the faucet. It may just be some sediment blocking the filter screen on the head. Unscrew the head and see if the water flows with the head off.
Jun 12, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
Aug 05, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Plumbing Logo
337 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
