Question about Toshiba Satellite A205-S4617 Notebook
Touchpad mouse will not double click
Mouse works ok to find items however when you want to double touch to accept or close programmes will not respond. Have to use the botton below. Run out of gaurentee today and PC world will not help.
Any suggestions welcome
    Master:
  • 413 Answers
If you go into the mouse and pointing devices in the controol panel you might be able to play with some of the settings so you can double click
Posted on Dec 29, 2008
How can i activate my mouse sensor???
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
Click the "Apply" button and then click the "OK" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
Sep 24, 2012 | Acer Aspire 5102WLMi PC Notebook
Sencitivity of touch pad how to adjust
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad. Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Change Touchpad Settings in Windows1. Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
2. Double-click the Control Panel's "Mouse" icon.
  • 3. Click the Touchpad tab. This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers. However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings. Refer to the "Warnings" section if this applies to your computer.
  • 4. Locate the "Scrolling Settings" area within the touchpad properties tab. Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes.
  • for MAC OS
  • Click the Apple menu and then select "Preferences."
  • 2
    Click the "Keyboard & Mouse" icon.
  • 3
    Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
  • 4
    Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
  • Dec 01, 2011 | Computers & Internet
    How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
    1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
    2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
    3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
    4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
    5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
    Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
    Touch pad is way too sensitve and any hint of accidentally touching it send mouse and/or characters all over the place. Makes this computer very difficult to use.
    Try these steps:
    1. Go to the Control Panel and double click on Mouse
    2. Go through the tabs in Mouse Properties window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
    3. On that tab, find the "Sensitivity" setting. Try changing this setting to lower the sensitivity of the touch pad to the degree you find acceptable.
    4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
    May 16, 2011 | Sony 4-660-223-01 Touchpad Keyboard
    My toshiba touchpad is not working
    1. Go to the "Control Panel" and double click on the "Mouse" item.
    2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
    3. On that tab, check & make sure that your touchpad is enabled. If it is not, then change the setting to enabled.
    If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
    Nov 02, 2009 | HP Pavilion dv4000 Notebook
    How can I disable clicking of touchpad. I did it before but it somehow started up again.
    If you have a touchpad icon down in the bottom right hand corner on windows task bar click it and you should see a menu that comes up. In that menu you should see tap to click. click that to disable your clicking for the touchpad.
    If the option is not there go control panel and click on hardware and sound, then devices and printer. under devices and printer you should see mouse or mouse properties. There should be a option in there to turn it off too.
    Oct 31, 2009 | HP Pavilion dv4000 Notebook
    Not working.
    Oct 31, 2009 | Dell F3534 Touchpad
    Touch pad too sensitive, it always messes me up when I'm typing
    You could try adjust the touchpad settings. Sometimes there is a touchpad icon in the taskbar that you can right click on to adjust the properties. You can also disable the pad and use a USB mouse instead.
    Sep 11, 2009 | Sony 4-660-223-01 Touchpad Keyboard
    My touchpad is too sensitive
    Nov 26, 2008 | GPX D1816 DVD Player
    Touch pad on/off utility
    Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
    7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
    Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
    Toshiba Satellite A205-S4617 Notebook Logo
    48 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
