Tray won't open.
Yamaha CDC 5 disc player. Tray won't open unless I pull or pry it. It tries to open but won't.
  • 85 Answers
Drive belt for draw is duff needs replacing
Posted on Jan 08, 2009
Yamaha cdc 697 cd player wont play disc
There are so many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 14, 2014 | Yamaha CDC-697 - CD changer 5-Disc CD...
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Note: CDC-625 unit won't open, no discs inside
Wait, wait!
I bought one of these units from a flea market for $5.00. It said the tray wouldn't open. I picked it up, and noticed the same thing you did. Humming motor, but the tray stayed put.
I opened it up to check things out, and all that was wrong was a (very) stretched out belt on the pulley that opened the tray. I replaced it with a rubber band and it has worked ever since. Once the rubber band wears out I'll replace it with a proper belt, but for now, it was a 2 minute fix that's lasted around 11 months so far. I really, really like this player, and plan to keep it working for a long time!
May 27, 2009 | Yamaha CDC-685 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Cd Tray
Hi Fred..
I've done about 100 CD transports so far.
Try changing any belts in the unit. On some CD players ,if the open/close belt is bad, it wont allow the CD to be read either.
Also,VERY lightly cleaning the laser lens and dusting the unit out helps too.
Dec 28, 2008 | Yamaha CDC-845 5-Disc CD Changer
5-Disc CD player
your tray is out of track, have to place it back. not that easy but you can try. dont force it of you can damage the tray or gears
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
My CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
Jul 21, 2006 | Yamaha CDC-755 5-Disc CD Changer
461 people viewed this question
 Grubhead
Grubhead
