Question about Whirlpool MH3184XP Microwave Oven
Nothing working - just quit. Power source ok.
Was working one day, dead the next.
  • donrenish Jan 20, 2009
    Do you remember the part number for the glass fuse?
There are 3 fuses in that microwave. I had a similar issue. The one that I had to replace was the little ceramic fuse that is in line after the big fuse which is connected to the main line.
I couldn't find the ceramic fuse but I replaced it was a glass one about a year ago and it has been working since then. The fuse if located on the right front panel.
Posted on Jan 20, 2009
    Problem Solver:
  • 4 Answers
Yup, had the same problem. For what it's worth, Radio Shack part 270-1066 seems to work as the replacement.
Posted on Apr 04, 2009
  • dawaddrgrd_f Apr 04, 2009
    I had the same problem. Replaced it with Radio Shack part 270-1066.  (No endorsement implied, but it seems to work.)
Need help with a power issue.
Most of the time you have defective door switches that make the fuse blow.
Nov 03, 2015 | GE JVM3670 Microwave Oven
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
Microwave Blowing Fuse. Fixed. After Day, Fuse Blows Again.
Hello there:
If you have all ready changed out the fuse and it has happned again i would first check to see that the fuse is the right one for the machine (i am sure that you did this but please recheck ) next i would look at the controle board as the next culprit it maay be failing expecially if there were any pops ar sparks that was noticed before the initial failure.
Also check to see if all of the wires by the board a re not loose or looked burned ar if there is any grease or anything like this around the area
And finally check to see if the plate is turning ok and not sticking cause this would cause the microwave to overload and it wil make every fuse you put in there fail after just a couple of uses ok
SO please try all of these things that i have explained to you
I hope this is very helpful for you.
Best regards Michael
Dec 12, 2009 | GE JE2160 Microwave Oven
Just quit suddenly. Power at oulet, nothing lit
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms (dead).
Nov 27, 2009 | Panasonic NN-T964SF Microwave Oven
Ge pvm2070 shut off and now will not come on
My PVM2070 Spacemaker Microwave quit working & its DEAD. I checked circuit braker, unplugged unit, checked power is ok, open/shut door, pushed very sensor buttons; its DEAD. Help??
Nov 09, 2009 | GE PVM2070SMSS Microwave Oven
Completely dead; has good power source and fuse ok
Where the door closes there is a a switch you have to take off the cover (plug out device) one of these switchs are probably burnt out
Sep 23, 2009 | Panasonic NN-S541 Microwave Oven
GE SpaceMaker JVM140001 just quit
Same thing happened to our unit. My wife had started cooking potatoes and we left house for an hour. Came back and unit was dead, nothing worked. Verified power @ plug. Unplugged, pulled control panel and checked fuse which is mounted @ top of circuit board (will now refer to as CB), back side of interface panel. It passed continuity test. Inspected wiring and was all intact, no sign of burn thru. Varistor visual also looked good, no discoloration or burns. Removed (5) fasteners that hold CB to interface and inspected back side. Noted minor "blackening" @ pin location #1 of the (5) pin plug immediately beneath fuse. Resoldered because connection looked poor. Plugged back in and tested, all features worked correctly!
Mar 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Whirlpool MH3184XP Microwave Oven Logo
533 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
