Toshiba D-VR4 DVD Recorder/VCR Logo
Linda Short Posted on Oct 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I use L1/L2? How can I enter 3-digit HD channels?
ernesto cuadra
Level 3:
Top Expert:
  • Toshiba Master 12,223 Answers
  • Posted on Oct 02, 2012
ernesto cuadra
Toshiba Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4078329
Points
34431
Use your instr. manual download from www. retrevo.com the manual has a lot of information, do not waste your time.
God bless you
Gta4 cheat codes ps3
Enter one of the following codes during game play. A small box will appear to confirm correct code entry.
Code: Result:
Circle, X, Circle, Square, Triangle, L1, R1, L2, R2. Any truck with trailer
R1, L2, R2, L1, Up, Down, Up, Down, Up, Down. Cop
Triangle, Left, Right, Circle, X, Up, Down. Drink beer
R1(2), L1, R2, Triangle, Left, Right, Square. Fly in the air
R1, L1, L2, Square, R2, Left, Right, Left, Right. Health
X, Circle, Circle, R1, Square, L1, Triangle. Helicopter
Up, Down, L2, R1, X, L1(2), Right, Left, Up. Listen to Back On My Grizzy in car
R2(2), Up, Circle, L1, L2, Down, Triangle, R1, Right(2). Listen to Crank That SouljaBoy in car
Circle, Right, Circle, Right, Left, Square, Triangle, Up. Lock wanted level
Up, Down, L1, L2, Left, Right, R1, R2, Square. Money
L1, Circle, X, R1, L2, R2, Square, Triangle, Triangle, X. Monster Truck
R1, Circle(2), L2, R2, Triangle, X, L1, Right. Never die
Press X, Circle, Triangle, Up, Down, Left, Right, Circle(2) while in an area with a lot of space. Private jet with pilot
R1(2), Left, Right, L2, Square, Triangle, L1, Circle. Run quickly
L1, R1, X, Circle, Triangle, X, R1, Square. Semi truck with trailer
R1, Circle, L1, X, Left, Down, L2, Up. Smoke
Up, Down, Left, Right, Circle(2), Left, Right. Tank
Square, Circle, X(3), Triangle, Square, Circle(3). Unlimited bullets
Square, Left, R2, Down(2), L1, Up, Circle. Unlimited money
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up, Right(2) Weapon tier 3
R1, L2, R2, L1, Up, Down, Left, Right, Up. Weapons tier 1
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up. Weapons tier 2
Cell Phone Passwords
At any time during the game, pull out Niko's phone and dial these numbers for the desired effect.
Password: Result:
468-555-0100 Change weather
486-555-0150 Get a different selection of weapons
486-555-0100 Get a selection of weapons
267-555-0150 Raise wanted level
267-555-0100 Remove wanted level
362-555-0100 Restore armour
482-555-0100 Restore health
227-555-0142 Spawn a Cognoscenti
227-555-0175 Spawn a Comet
938-555-0100 Spawn a Jetmax
625-555-0150 Spawn a Sanchez
227-555-0168 Spawn a SuperGT
227-555-0147 Spawn a Turismo
359-555-0100 Spawn an Annihiliator
227-555-0100 Spawn an FIB Buffalo
625-555-0100 Spawn an NRG-900
Multiple operations in single command on new TI84
Run SetUpEditor to restore the list names L1, to L6
100->dim(L1) to set the dimension of L1 to 100
100->dim(L2) to set the dimension of L2 to 100.
Since you are going to store the random numbers in L1, you should use L2 as the FreqList. All elements of L2 should be 1. When you create it all its elements are 0. One way to fill it with 1's is 10 run the command
L2+1>L2; Add 1 to each number and store the results in L2 (overwrite the 0 values)
Perform a blank run of 1-var Stats to get the chance to set the default lists.
1-var Stats L1, L2 ENTER
Type in your command
randNorm(64.5,2.5,100) STO> L1:1-var Stats L1, L2 ENTER.
Use the Catalog to type in the 1-var Stats commnad so that you can type in the Lists L1 and L2 without opening the 1-var Stats configuration screen.
Do what you have to do with the statistics you generated.
To rerun the two commands again, press [2nd][ MODE] to (QUIT)
or press the sequence [2nd][ENTER] to have the last (ENTRY) echo on the main screen. Press ENTER to run again
Hoe it helps.
Gta vice city unlocked code
Attract FollowersTo draw a crowd that follows you wherever you go, enter this code during gameplay: CIRCLE, X, L1, L1, R2, X, X, CIRCLE, TRIANGLE. (You can have your followers beat up other people if you hit them first.)
Cars FloatTo make cars able to drive on water, enter this code during gameplay: RIGHT, R2, CIRCLE, R1, L2, SQUARE, R1, R2. This cheat is helpful when going after hidden packages in the water.
Change the WeatherTo change the weather, enter one of the codes listed below:
  • Normal: R2, X, L1, L1, L2, L2, L2, DOWN
  • Rainy: R2, X, L1, L1, L2, L2, L2, CIRCLE
  • Foggy: R2, X, L1, L1, L2, L2, L2, X
  • Overcast: R2, X, L1, L1, L2, L2, L2, SQUARE
  • Sunny: R2, X, L1, L1...
Cheat: Low GravityDuring game play, press RIGHT, R2, CIRCLE, R1, L2, DOWN, L1, R1. Press UP while you accelerate to make the car hover off of the ground.
Even More WeaponsEven more weapons--chainsaw included! Press R1, R2, L1, R2, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, DOWN, DOWN during gameplay.
Fast MotionDuring gameplay, press TRIANGLE, UP, RIGHT, DOWN, L2, L1, SQUARE.
Faster TrafficTo make the traffic speedier and less easy to jack, enter this code during gameplay: R2, CIRCLE, R1, L2, LEFT, R1, L1, R2, L2.
HealthTo get instant health, enter this code during gameplay: R1, R2, L1, CIRCLE, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, RIGHT, UP.
Improve Driving SkillTo make yourself better behind the wheel, enter this code during gameplay: TRIANGLE, R1, R1, LEFT, R1, L1, R2, L1. Then press L3 to jump when in a vehicle.
Instant Body ArmorTo get body armor in an instant, press these buttons during gameplay: R1, R2, L1, X, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, RIGHT, UP.
Kill YourselfTo commit suicide on the stop, press these buttons (this will also reset your outfit): RIGHT, L2, DOWN, R1, LEFT, LEFT, R1, L1, L2, L1.
Media LevelPress R2, CIRCLE, UP, L1, RIGHT, R1, RIGHT, UP, SQUARE, TRIANGLE during play to display your media level.
More WeaponsThis batch includes the rocket launcher, machine gun, katana, grenades, pistol, shotgun, and uzi. During gameplay, press R1, R2, L1, R2, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, DOWN, LEFT.
New TiresWhen your tire gets blown out enter R2, L2, L1, CIRCLE, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, RIGHT, UP.
Parking MeterDrive over parking meters to empty cash into the streets. It's free money!
Pedestrians Go NutsTo make the pedestrians attack anything in sight, enter this code during gameplay: DOWN, LEFT, UP, LEFT, X, R2, R1, L2, L1. This one has similar results: DOWN, UP, UP, UP, X, R2, R1, L2, L2.
3helpful
2answers
My calculator is TI-83 plus. I get Err: data type every time I want to use lists to calculate something. For example I enter 5,10,15,20,25 in list 1 and 5,5,5,5,5 in list 2. Then in list 3 I type L1/L2,...
You can't manipulate lists like that.
{5,10,15,20,25}[STO>]L1
{5,5,5,5,5}[STO>]L2
These will input your lists properly. I'm not sure what you're trying to do, but if you're just trying to divide every entry in L1 by 5 and store it in L3, you could accomplish that with:
L1/3[STO>]L3
Also, this page gives a lot of helpful tips on using lists on a TI-83.
http://pages.central.edu/emp/lintont/ti83/html/lists.pdf
Hope this helps!
1helpful
How do i clear the L1 L2 so on cells?
I do not understantd what you mean by the so on cells words.
1. To clear all lists
Press [2nd][CATALOG] to access the list of commands. Scroll down till the fat right arrow point to ClrAllLists. Press [ENTER][ENTER] to execute the command. Screen displays Done.
2. To clear the list L1 completely
Press [STAT][4:ClrList]; command echoe on main screen as ClrList . You must specify what list you want to clear. To clear L1, you insert at the place of the cursor L1 and press [ENTER]. But to insert L1, you press [2nd][1] (L1) and press [ENTER].
3. Clear L1 and L2 completely you do as in point 2.
Press [STAT][4:ClrList] [2nd][1] [,] [2nd] 2 (L2). On screen command appears as ClrList L1, L2. Press [ENTER] to execute it. Screen displays Done
4. To clear a number in a cell.
Press [STAT][1:Edit]. The list editor opens. Move cursor to the top of the list, say L1. and highlight the heading
The whole list appears on the commande/edit line.
Press [ENTER].
Cursor moves to the entry line where all elements on the list appear between { }.
Use the cursor to the value you want to remove and press [DEL]. Do not leave unneeded commas.
Hope it helps.
Panasonic PV-9451 VCR, When setting up the VCR to record a channel, the only channel options are Channel 02 thru 25 and L1 And L2. What has to be reset with the digital cable input??
You will need to use L1 or L2 (one is probably on the front of the VCR, and the other on the back, they should be labeled).
YOu need to plug the digital receiver's output into L1, or L2, and set the VCR to record the one you're using. Then set it to the time you want, and then set the channel on the digital box tho the one you want.
One Channel, One time. (or recurring daily, if your VCR allows daily recording from L1,2)
1helpful
2answers
Grandautosandandreascheat
Cheat: Infinite Lung Capacity
During game play press DOWN, LEFT, L1, DOWN, DOWN, R2, DOWN, L2, DOWN
Cheat: Cars Fly
During game play press UP, DOWN, L1, R1, L1, RIGHT, LEFT, L1, LEFT
Cheat: Taxis Have Nitrous and L3 Bunny Hop
During game play press UP, X, TRIANGLE, X, TRIANGLE, X, SQUARE, R2, RIGHT
Cheat: Weapon Aiming While Driving
During game play press UP, UP, SQUARE, L2, RIGHT, X, R1, DOWN, R2, CIRCLE
Cheat: Traffic is Fast Cars
During game play press UP, L1, R1, UP, RIGHT, UP, X, L2, X, L1
Cheat: Reduced Traffic
During game play press X, DOWN, UP, R2, DOWN, TRIANGLE, L1, TRIANGLE, LEFT
Cheat: Spawn Dozer
During game play press R2, L1, L1, RIGHT, RIGHT, UP, UP, X, L1, LEFT
Cheat: Gangs Control the Streets
During game play press L2, UP, R1, R1, LEFT, R1, R1, R2, RIGHT, DOWN
Cheat: Massive Bunny Hops
CJ has the ability to bunny hop on the bmx over massive distances: TRIANGLE, SQUARE, CIRCLE, CIRCLE, SQUARE, CIRCLE, CIRCLE, L1, L2, L2, R1, R2
Cheat: Beach Party
Pedestrians turn into girls wearing swimsuits. Vehicles are also beach style and CJ will be dressed in shorts and sandals. While playing Grand Theft Auto: San Andreas enter: UP, UP, DOWN, DOWN, SQUARE, CIRCLE, L1, R1, TRIANGLE, DOWN
Cheat: Spawns a Stunt Plane
CIRCLE, UP, L1, L2, DOWN, R1, L1, L1, LEFT, LEFT, X, TRIANGLE
Cheat: Monster Truck
RIGHT, UP, R1, R1, R1, DOWN, TRIANGLE, TRIANGLE, X, CIRCLE, L1, L1
Cheat: Vehicle of Death
Any vehicle the player is using becomes invincible and gains the ability to instantly destroy anything it touches. L1, L2, L2, UP, DOWN, DOWN, UP, R1, R2, R2
Cheat: Get Parachute
LEFT, RIGHT, L1, L2, R1, R2, R2, UP, DOWN, RIGHT, L1
Cheat: Full Health, Full Armor, $250,000
To have all of the above, press the following while playing GTA: San Andreas: R1, R2, L1, X, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, RIGHT, UP.
Cheat: Weapon Set 2
To unlock the Knife, Pistol, Sawnoff Shotgun, Tec 9, Sniper Rifle, Flamethrower, Grenades, Fire Extinguisher in Unlock some new rides in GTA: San Andreas enter: R1, R2, L1, R2, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, DOWN, LEFT.
Cheat: Weapon Set 3
You can unlock the Chainsaw, Silenced Pistol, Combat Shotgun, M4, Bazooka, Plastic Explosive in Unlock some new rides in GTA: San Andreas during gameplay by pressing R1, R2, L1, R2, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, DOWN, DOWN.
Cheat: Weapon Set 1
To unlock the Bat, Pistol, Shotgun, Mini SMG, AK 47, Rocket Launcher, Molotov Cocktail, Spray Can, Brass Knuckles in Grand Theft Auto: San Andreas enter: R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Right, Up.
Cheat: Get Rhino
To make a Rhino tank fall from the sky, press the following during gameplay: CIRCLE, CIRCLE, L1, CIRCLE, CIRCLE, CIRCLE, L1, L2, R1, TRIANGLE, CIRCLE, TRIANGLE.
Cheat: Wanted Level Up
To raise your Wanted Level, enter the following during gameplay: R1, R1, CIRCLE, R2, LEFT, RIGHT, LEFT, RIGHT, LEFT, RIGHT.
Cheat: Blow Up All Cars
To make all vehicles explode, press the following during gameplay: R2, L2, R1, L1, L2, R2, SQUARE, TRIANGLE, CIRCLE, TRIANGLE, L2, L1.
Cheat: Wanted Level Down
To erase your Wanted Level, enter the following during gameplay: R1, R1, CIRCLE, R2, UP, DOWN, UP, DOWN, UP, DOWN.
Cheat: Flying boats
During game play press R2, CIRCLE, UP, L1, RIGHT, R1, RIGHT, UP, SQUARE, TRIANGLE
Cheat: Spawn Bloodring Banger
During game play press DOWN, R1, CIRCLE, L2, L2, X, R1, L1, LEFT, LEFT
Cheat: Spawn Ranger
During game play press UP, RIGHT, RIGHT, L1, RIGHT, UP, SQUARE, L2.
Cheat: Spawn Hotring Racer 1
During game play press R1, CIRCLE, R2, RIGHT, L1, L2, X, X, SQUARE, R1.
Cheat: Spawn Hotring Racer 2
During game play press R2, L1, CIRCLE, RIGHT, L1, R1, RIGHT, UP, CIRCLE, R2.
Cheat: Spawn Romero
During game play press DOWN, R2, DOWN, R1, L2, LEFT, R1, L1, LEFT, RIGHT.
Cheat: Spawn Stretch
During game play press R2, UP, L2, LEFT, LEFT, R1, L1, CIRCLE, RIGHT.
Cheat: Spawn Trashmaster
During game play press CIRCLE, R1, CIRCLE, R1, LEFT, LEFT, R1, L1, CIRCLE, RIGHT
Cheat: Spawn Caddy
During game play Press CIRCLE, L1, UP, R1, L2, X, R1, L1, CIRCLE, X
Cheat: Bounty on Your Head
While playing Grand Theft Auto: San Andreas press DOWN, UP, UP, UP, X, R2, R1, L2, L2.
Cheat: Perfect Handling
During game play press TRIANGLE, R1, R1, LEFT, R1, L1, R2, L1.
Cheat: Aggressive Traffic
While playing Grand Theft Auto: San Andreas press R2, CIRCLE, R1, L2, LEFT, R1, L1, R2, L2
Cheat: Drive on Water
During game play press RIGHT, R2, CIRCLE, R1, L2, SQUARE, R1, R2
Cheat: Black traffic
While playing Grand Theft Auto: San Andreas press CIRCLE, L2, UP, R1, LEFT, X, R1, L1, LEFT, CIRCLE
Cheat: Pink Traffic
During game play press CIRCLE, L1, DOWN, L2, LEFT, X, R1, L1, RIGHT, CIRCLE
Cheat: Suicide
Cheat: Faster Clock
CIRCLE, CIRCLE, L1, SQUARE, L1, SQUARE, SQUARE, SQUARE, L1, TRIANGLE, CIRCLE, TRIANGLE
Cheat: Sunny Weather
Cheat: Faster Cars
RIGHT, R1, UP, L2, L2, LEFT, R1, L1, R1, R1
Cheat: Pedestrian Riot- Cannot be disabled
Cheat: Overcast Weather
R2, X, L1, L1, L2, L2, L2, TRIANGLE
Cheat: Faster Game Play
During game play press TRIANGLE, UP, SQUARE, SQUARE, L2, L1, SQUARE
Cheat: Foggy Weather
During game play press R2, X, L1, L1, L2, L2, L2, X
Cheat: Slower Game Play
During game play press TIRANGLE, UP, RIGHT, DOWN, SQUARE, R2, R1
Cheat: Rainy Weather
During game play press R2, X, L1, L1, L2, L2, L2, CIRCLE
Cheat: Pedestrians Have Weapons
R2, R1, X, TRIANGLE, X, TRIANGLE, UP, DOWN
I am looking to use the stat feature on my calc, can you assist ?
Assuming you already have L1 and L2 stored:
2ND L1 ^ 2 STO> 2ND L3 ENTER
2ND L2 ^ 2 STO> 2ND L4 ENTER
ExpReg
try looking through this:
http://online.redwoods.cc.ca.us/instruct/kiyokoya/ExpReg/index.htm
also, you may find havina an algebra system on your omputer helpful a nice free one is Maxima:  http://wxmaxima.sourceforge.net/wiki/index.php/Main_Page
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
