My eclipse 180 mp3 player is not being recognized by my computer
Hi wfowler05...
This is for an external hard drive, but the same applies to your MP3 player
The problem is being caused by the Logical Disk Manager
Administrative service and possibly the logical Disk Manager service
not being started or the services might be disabled. to solve the
problem, click on the "Start" menu, click the "Run" command, and then type
in the box: services.msc , scroll down until you see both the above services.
right click on each of the services about and select properties, on the
general tab, change the startup type to "automatic" and click the start
button under the service status. do this for both of the services, and
that should will fix your problem."
For Windows 2000 and XP:
Right click on My Computer.
Choose Manage (This will open the Computer Management window).
Go to the Storage category and select Disk Management
Right click the new drive (usually listed as Hard Disk 1) and "initialize"
You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended for most users.
External hard drive can not be recognized, are more common on computer
failures, what's the reason caused this failure?
1, Setting the CMOS parameters
If you never used the USB external device, there may occur the case:
The system can not detect USB hard drive even if the driver is properly
installed, which was mainly due to the motherboard CMOS default port is closed, if not set to
open state, it naturally Windows can not detect the external hard drive. In order to solve this
problem, we can re-boot into the CMOS settings, and set "Assign IRQ For USB" to "Enable" in
"PNP / PCI CONFIGURATION" column, now the system can be assigned to the USB port available
interrupt address.
2, Power shortage
As the USB drive need to consume some power when it at work, if directly through the USB interface
to take power, the power supply may be not enough. Thus, almost all of the external hard drive
comes with a separate external power supply or a PS2 keyboard to take power transfer interface,
at this time you should connect external power supply or through the transfer cable ps2 connected
to keyboard to ensure that it have provided adequate power to the external hard disk,
recommended that you should ensure the external hard drive have adequate power supply when you
use it, otherwise, the external hard disk is likely to be damaged due to insufficient power
supply.
3, USB extension cable fault
USB interface type does not match the external hard disk interface ,this case caused it can not
be used. For example the standard USB interface of the computer configuration is 1.1, while the
external hard drives purchased are USB 2.0, which requires the cable connected computers and
external hard disk must support USB 2.0 standard. Because high-speed mobile device plug in a
low-speed hub, the device may not be properly installed, and some people use external hard disk
while using USB flash drives, For convenience, they directly used USB 1.1 standard cable that
supplied by USB flash drives, as a result, the USB 2.0 standard hard drive not be recognized
correctly. Just replace it by the USB 2.0 standard cable can solve this problem.
4, Windows version is too low
Pre-Windows 98 operating system does not support USB peripherals, so in any case to install the
driver, set the CMOS parameters are unable to make normal use of external hard disk. In this
case, one solution is to upgrade the operating system up to Windows 98, another way is to
Microsoft's official site, download the appropriate patch to make it can identify mobile hard
disk.
5, The system is set incorrectly
When installed driver, the external hard disk icon will be seen on the Device Manager for some
Windows 98 users, but the Explorer does not include the corresponding letter identification,
which is improper system settings. In the Device Manager, double-click the Hard Drive icon, and
click the pop-up window in the "Properties" button, and you could see disconnect, could be
deleted, synchronous data transmission and Int 13 unit four options, of which "could be deleted "
is no tick in front of the system, and simply check this option to restart your computer, you can
see in the Explorer, the new external hard disk drive letter.
While the failure of the external hard disk does not recognized are more the reasons, but
generally not the USB interface or external hard disk's own fault, so it requiring us to consider
some more from around the association when exclude it, I believe you can successfully use the
external hard disk.
Hi I had the same problem and solved it like this assuming that you are running windows xp
With your external casing powered-up (it does not get power through USB does it?) and your WinXP
PC running, plug in the USB.
You should hear 'chime', what happens then?
If harddisk is recognised here, but does NOT have a drive-letter and cannot be seen in Windows
Explorer, the answer is in Windows Disk Management
Go Administrative Tools > Computer Management > Disk Management. ( on left column)
Maximize this page. Physical Drives appear at the bottom; Logical Drives at the top.
Hopefully your drive will appear at the bottom (physically), you must then 'import' it into the
Windows installation
; Windows will put its 'signature' on the drive and assign it a logical drive letter :^)
you can try to format it here if it is new and has no info on it , check back to My computer and see if present.
Please take time to rate me
