Kenmore 90 Series washer needs two spins to remove water
I have a Kenmore 90 series washer, model 110.28912790. The washer works fine other than not getting the water out of the clothes on the first spin. Always have to spin twice to extract water. Never any water left sitting in tub after first spin. I have replaced direct-drive coupler and the pump. No change. The tub seems to spin fast, but how do you determine whether it is fast enough or spinning long enough? My wife is getting very annoyed by having to spin twice every time. I have watched the tub spin with the top open. It spins fast enough that everything becomes a blur, and water is always ejected from the drain hose, but it apparently is not spinning fast enough or long enough to extract most of the water from the clothes. HELP
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Posted on Mar 30, 2010
My 90 series Kenmore washer spins but doesn't
The most likely problem is the drain pump.
Jun 26, 2011 | Kenmore Washing Machines
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore Series 90 washer. Will pump the water, does not spin
Replace the motor coupling between the motor and transmission its very easy if you tilt the machine back and remove the two screws holding the motor brackets.
Mar 28, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Washing Machines Logo
449 people viewed this question
Top Washing Machines Experts
