Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Noisy agitator I bought my Whirlpool washer in fall 2004; recently it's started making VERY LOUD agitating sounds, even with light loads. When it's agitating even with a small load, it sounds like it's jam packed full and is really straining hard to get the work done. Any ideas? I'm not extremely proficient with do-it-yourself repair jobs, but if it's relatively easy, I'll try it!
    Novelist:
  • 114 Answers
SOUNDS LIKE THE CLUTCH ASSEMBLY OR MAYBE BEARINGS ... A GOOD APPLIANCE REPAIR COMPANY USUALLY OFFERS A "FLAT-RATE" DIAGNOSTIC CHARGE THAT VERIES FROM 30-50 DOLLARS. LABOR AND PARTS ARE ALWAYS EXTRA. MOST ALL WASHER MANUFACTURERS HAVE "SPECIALTY" TOOLS TO PREVENT THE HOME-OWNER FROM ADJUSTING THE CLUTCH OR MAKING REPAIRS. YOU HAVE TO DECIDE WETHER ITS WORTH REPAIRING. NEVER SIGN ANYTHING. OR LET A REPAIRMAN START WORKING AFTER HIS DIAGNOSTIC CHECK ... UNTIL A TOTAL COIST FOR REPAIR IS REACHED.
Posted on Apr 28, 2007
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
What is causing my washer to make a humming sound when agitating
Maybe worn pump. easy to find out.
disconect from motor and put into agitation
cycle , no noise > bad pump. still noisy then
maybe transmission> buy a rebuilt from
a Dasa distributor call toll free 1-866-327-2634 to find one near you.
May 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Loud clicking while agitating
You may have debris stuck in the pump.
This can cause the clicking sound and also bind the pump causing a circuit overload.
Feb 21, 2009 | Whirlpool WTW5550S Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator is noisy
I think you may have a bad transmission. this uses a direct drive transmission
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin and agitator not working
VERY POSSIBLY THE MOTOR/GEARBOX COUPLING HAS BROKEN. NEEDS TO BE REPLACED. SWITCH WASHER OFF THEN TILT WASHER 60 DEGREES BACKWARDS AND CHECK COUPLING. THERE IS A KIT WHICH CAN BE BOUGHT. DEFINATELY A D.I.Y. REPAIR.
Aug 17, 2007 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
94 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
