Question about Dell SE198WFP LCD Monitor
MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
I RECENTLY BOUGHT &TRIED TO INSTALL THE MONITOR, SELF CHECK SAYS ITS FINE BUT IT IS NOT.
  • 3 more comments
  • newHRTsldier Jan 03, 2009
    Same deal here. When I connect with VGA, it's not a problem, but when I try DVI it won't bring up anything but Power Save Mode. It's really pissing me off.
  • Anonymous Jan 17, 2009
    Same thing... I've looked into making sure I have the right DVI Cable (DVI-D single) which shipped with monitor. Video card DVI-D output is Dual.. Shouldn't be a problem, but cannot get monitor to work digitally.
    I have a Nvidia GeForce 2 card. Should be able to plug in and go...?
  • Anonymous Jan 23, 2009
    I have the same problem, when i plug my blue cord into the video card directly my screen does not come on and goes into power save mode..need help!
  • raviabcd Mar 16, 2009
    Same problem; connected to HP Pavilion t588d desktop; works fine with VGA; but goes to power save mode when dvi cable is connected
  • FLUFFEH Apr 21, 2009
    Same thing happened to me i got a brand new video card got a nice power supply for it too and now i cant use them (where do i do that in the vista control panel because it is not in my monitor control panel)
I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
Posted on Feb 13, 2009
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
My monitor won't turn on, when boot up it goes
the problem is not the monitor. the video card itself. replace it or before you do that, try reinserting the video card or clean the contact before you reinsert it..
Oct 29, 2009 | Dell SE198WFP LCD Monitor
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
MONITOR COMES ON FINE I GET A FLICKER AND THE SCREEN GOES BLACK
It’s very likely your monitor has failed. Most Dell monitors have a 3 year warranty, so if you got it before three years, you could get it replaced by calling Dell. If you got the monitor with the computer, you can check your warranty online from with your computer Service Tag from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen . If you bought the monitor separately, you would need an Order Number or Customer Number for the purchase, or you could call Dell support and they could pull it out with your registered phone number. Dell would also need the serial number (starting with CN XXX..) from the back of the monitor.
Monitor User guide for SE198WFP available at http://support.dell.com/support/edocs/monitors/SE198WFP/en/preface.htm
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell SE198WFP LCD Monitor
Power save mode, i dont know how to get out of it
2 option disable it to display/LCD menu and windows power option under control panel
Jan 23, 2009 | Dell SE198WFP LCD Monitor
Second monitor - 'power save' mode.
Firstly, you can try to switch the second with the first monitor. Secondly, use only the second monitor as a main monitor and check that if there is still a problem or not. It might be because of BIOS. You can check and update BIOS with your computer manufacturer.
Feb 20, 2008 | LG L1918S-BN (Black) Monitor
Dell SE198WFP LCD Monitor Logo
1,284 people viewed this question
Alun Cox
