Question about Toshiba Satellite A135-S2276 Notebook
Wireless not working
I have a toshiba satellite A 105. It won't connect to our wireless (my roommate's computer will, so it's not the router) and I have a wireless printer I can't connect to either.
  • brianneomaha Jan 02, 2009
    Haven't tried- jargon too technical- have no idea what any of this means or what to do or look for or what to do. SO maybe this would help if I knew what you were talking about.
  • brianneomaha Jan 03, 2009
    idk where user manual is. it's cool, i have a fried who will check it out when he has time- thank you.
    Sergeant:
  • 366 Answers
Be sure Wireless Lan feature activated on your PC (check user manual).
Get network params from your Roommate PC (Protocol: WEP or WPA? Security key or Passphrase? Radio Band"A B G or N)
Replicate same info on your PC.
OR try connecting to a free access point (no password required)
if you have one available in range: Right click on Wlan Icon on Systray select "View available wireless network" connect to any unsecure network OR to a secure network if you know password
Posted on Dec 29, 2008
  • Pat Batta
    Pat Batta Jan 03, 2009
    Do you k now if Your Wlan is ON?
    Did you check your user manual?
    Please confirm to proceed with any further step.
  • Pat Batta
    Pat Batta Jan 04, 2009
    FN + F8 : To check if Wireless is enabled
    User manual could be found here
I have HP Pavilion Entertainment PC and I'm currently connected to the internet via a wirelss router. My roommates are also connected to the same router and they have not had any issues with...
Try positioning your computer next to the router - or within line of sight of the router - see if the limited connectivity thing comes up. It probably won't. Then try placing your laptop at the same spot where your roommate(s) normally uses his or hers or their computers and see if that makes any difference.
Wireless signals can go thru walls, or bounce off of anything that it can't go thru - so we're all trying to catch a good bounce and hence, location matters a lot. Sometimes moving a wireless router can make a huge difference - like moving it from behind the TV to above the TV for better broadcasting (cause the signal ain't gonna go thru a TV's power supply). Anyway, that'd be how I'd go about troubleshooting this issue....
Sep 08, 2011 | Computers & Internet
My roommates laptop is connecting to the internet, mine won't
Sometimes the key length would change for security purposes. What you have to make sure is that you are entering the correct network key.
Use a connected computer like your roommates laptop or hardwired connect you laptop to the router using an ethernet cable to access the setup page of the router.
In your browser's address bar, type 192.168.1.1. By default, leave the username blank, password is admin.
Go to Wireless -> Wireless security.
You will see the network key. Just copy that and enter it on your laptop.
I hope this helps!
Jul 12, 2010 | Linksys WRT160N Wireless Router
Toshiba Satellite 1905-S303 needs a wireless card.Whrer and what should be ordered?
Wireless cards come in a variety of formats and are available from Best Buy, Walmart, Target and half a dozen other locations. You can get a USB version or a PCIMCIA format that will work on your computer. These will work to connect to routers and some WI-FI hot spots. If your looking for something that will connect you to the internet without a wireless router or Hot Spot you need to get one from your cell phone carrier.
Jul 08, 2010 | Toshiba Satellite 1905-S303 Notebook
I can not connect this wireless router to my toshiba satellite laptop x205. I have tried everything I know. Machine is running Windows Vista. There is another laptop in the house (an Acer) that connects...
I fixed the problem. The problem is that Toshiba Satellite Laptops do not like Channel 6, so I moved it to Channel 11 and both laptops were working on it.
Jan 12, 2010 | Linksys WRT160N Wireless Router
NO Wireless on Toshiba Satellite
attach your wireless router with modem then turn on the pc .. there is a pin whole at back of wireless router pin it in it would reset all of your setting . than go to internet explorer address bar type the IP 192.168.1.1 ususaly and the passward would be admin as well as user name .. then set the setting according to your requirment with out opposing IP ..than first turn of every thing computer modem router
then after 20 min first switch on the wireless router then modem and then your computer .. you will get connected through wireless router..
Jun 25, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Can't turn on wireless on computer
which toshiba satellite pro ?
is wireless on at the laptop?
sometimes a combination: Button FN & F1-F12
try to connect router via ethernetcable:
inside routerconfiguration enable wlan
sometimes routers have a switch outside to enable/disable Wlan
is there a WLAN-LED at the router?
May 05, 2009 | Computers & Internet
Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
Jul 08, 2008 | Toshiba Satellite A105 Notebook
Internet connection
Amber,
My guess is, as you also have guessed, the internal wireless card. Since it is under warranty, there should not be charge for it but I don't know the details of your extended warranty.
Jun 18, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
