Question about Hotpoint BWM12 Front Load Washer
Hotpoint BWM129 integrated - no drain, no spin
My washing machine stops just before getting to "rinse" on dial, then I have a constant lights on both "super wash" and "rinse hold" with door locker light flashing rapidly. I have tried all the obvious to fix it myself; filter cleaning, checked for drain hose blockage, disconnected the appliance for a while to reset and changed to different sets and programs, but nothing seems to work. It gives the same error lights after a few minutes on. Is there any button combination to use to fully reset the machine or anyone knows what the problem might be?
  • keith4664 Jan 08, 2009
    I have the same problem, the machine goes through it's cycle and stops with the drum full off water then the door light flashes rapidly with the super wash and rinse hold lights also flashing!
vest6
  • 196 Answers
SOURCE: hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Posted on Jan 02, 2008
SOURCE: Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Posted on Jun 10, 2008
ginko
  • 19396 Answers
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Posted on Feb 18, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint bwm129 wont finish a cycle. super wash
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Posted on Dec 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Hotpoint bwm129 Led flashes rapidlyat the same
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I have a hotpoint bwm129 1200 spin and I can't drain the water out of the washing machine. I have taken out the filter as it was clogged, cleaned up but the rest of the water has not come out of the d
You should be able to drain the water out by laying the drain hose down into a bowl. Does the pump function properly on final spin, that usually clears the water to allow the door to open. Parts are obtainable from Hotpoint Spares.co.uk.
Jan 29, 2015 | Hotpoint BWM12 Front Load Washer
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Control dial moves along fine but drain,spin, rinse never happen
replace the water pump. about 46 dollars and a 20 minute job.
Jun 24, 2009 | Maytag Washing Machines
I have the hotpoint BWM129 super silent 1200 spin, recently the machine has stopped draining water even after spin cycle has finished , I also have constantly flashing lights which are super wash and delay...
Feb 18, 2009 | Hotpoint BWM12 Front Load Washer
Hotpoint Aquarius WMA34 not progressing through wash cycle
hi
iwould think it is the programer may have failed mechanically not moving on
cheers
grant
Oct 23, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
327 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
