Question about Mercury P4VM800M7 Motherboard
Required to updae bios, how can i do
MY SYS TEM RESTART AUTOMATICALY AND AFTER IT SHOWING OPERATING SYSTEM IS MISSING
AFTER CLEAR A BIOS SYSTEM IS START NORMALY
    President:
  • 2,110 Answers
Posted on Dec 29, 2008
  • Sibananda Jena
    Sibananda Jena Dec 30, 2008
    Why did u rate me In Appropriate...Is the link not contain the BIOS..pls clarify or change the rating .......thank you
No operating system found
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and reseat (reconnect). Check BIOS. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 13, 2012 | Computers & Internet
Save not cmos on mainboard asus p4p800s-x chek batry&clear cmos but not resolv save not cmose
ASUS CrashFree BIOS2
The CrashFree BIOS 2 feature now includes the BIOS auto-recovery function in a support CD.
Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional R
C.P.R.(CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Just simply restart the system, the BIOS would show the previous setting and then users can amend the CPU setting again.
ASUS EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
hope this helps you
Mar 03, 2011 | ASUS P4P800S-X (610839118175) Motherboard
How to solve this problem """operating system not
Hi sirajshah_mu,
This error message will appear if the Computer is not detecting the internal Hard Disk Drive or when the Operating System is missing.
First, please try resetting the BIOS to the default values to check if that resolves the issue. To reset the BIOS to the default values, restart the Computer, press and hold the F2 Key to access the BIOS, then, please press the F9 to load the default values and F10 to save and exit. After that, please try restarting the Computer to check if that work.
If the issue still persists, please check if the Hard Drive is listed in the BIOS main window. Also, please try disconnecting all the external Devices connected to the Computer.
If the issue is not resolved after performing the above steps, you may need to re-install the Operating System in the Computer using the Recovery Partition. It is required to have the exact model # of the Computer to provide the necessary information on Recovery. If the issue still persits, please let me know the results of the above steps and the exact model # to assist you further.
Hope this helps.
Please free to get back to me if you have any further questions or require further assistance.
Thank you for using FixYa.
Dec 17, 2010 | Sony VAIO Notebook
Hi I have formatted my hdd and than have copied some data file on it as private documents. After I have put on the hdd to try to install the operation system, but first black screaming is file NTLDR...
Make sure you are pressing the right key to enter the bios normally this is the Del key.Some computers use the F1 key and others you have to press Shift+Crtl+Esc once you in the bios set your boot device to your CD Rom. Put in your operating system disk. Then save and restart your bios. This should allow you to reinstall the operating system. The NTLDR is the boot file for windows operating systems.
Nov 26, 2010 | Computers & Internet
Message tells me it can not find the hard drive when I try to reload windows XP after getting the error message on a corrupt or missing system32drivers ntfs.sys
Restart the computer and press the necessary key to enter BIOS setup and see if the hard drive is listed in the BIOS
If it is not listed in the BIOS you need to replace the hard drive
Sep 24, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
At start no operating system found
By your description either the drive has died or somehow the BIOS has been changed to not be able to see the drive. Can you run setup on startup to get into the BIOS? From there you should be able to see if the BIOS is detecting the drive. Mose BIOS setups have a selection to automatically detect the drive. I would try that.
Mar 15, 2009 | Compaq Presario 1800T Notebook
I can;t boot my laptop compaq Evo N610c from cd-rom drive
Disable the SATA option in BIOS settings then it automaticaly takes the CD ROM
Mar 04, 2009 | Compaq Evo N610C Notebook
SETTINGS FROM FRENCH TO ENGLISH
There are three areas you can (or cannot) set languages.
1. Operating system (Windows most probably) Unfortunatelly you cannot change the operating system language. (Except Vista Ultimate and Vista Enterprise edition and having the right MUI)
Other windows languages are not changeable without re-installing the current op.sys. and of course you have to have the right language based op. sys. on cd or on dvd.
2. BIOS language change: It can be change if the BIOS flashable and the BIOS provider released the required version in your language. (Mostly default language is english) Some BIOS can be set to other language without flashing it. Look in the BIOS menu first. It's not easy to find if its set to another language but try every sub menu than you will find it.
3. The regional and keyboard settings. Its a basic setup in the control panel--->Regional and Language (GLOBE ICON) ---> firs and second tab you have to choose the desired language.
Nov 28, 2008 | Gateway Computers & Internet
Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Thanks
Dec 12, 2007 | Intel D945GNT Motherboard
Mercury P4VM800M7 Motherboard Logo
49 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
