Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Hard disk and ram size
What is maximum hard disk and ram cpacity that i can upgrade for my system that has p4 processor with intel 915 g motherboard
  • senthil j Jan 05, 2009
    Hi , Thanks for reply , Can you please tell whether the ram used in intel 915 gvwb mother board is ddr1 or ddr 2 , i use windows xp ,can you tell what is max hard drive i can use for this os
    Problem Solver:
  • 17 Answers
With xp are you going to use the 32-bit file structure or 64-bit fs? this determines weather you can use 1GB memory (32-bit) or 2GB (64-bit). hard drive size will also be determined by which service pack of xp you are running. xp- home edition- 137GB hhd, the other service packs and the bit size of your file structure will allow larger hdd's.
Posted on Jun 22, 2009
Hello
i m using motherboard of intel915gvwb. but i found there is no
agp slot in it. now i want to add graphic card in it. so how can
i add this card in it.
pls suggest some remedy.
Posted on May 06, 2009
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Here's a quote from a site which sells that board.
The D915GAGL provides 4 DIMM sockets using 184-pin DDR with a total capacity of up to 4GB. You can install DDR PC3200/2700 memory modules.
I see yours isn't an AGL, but if you open up your case and see that there're four slots for ram, then it should have the same limit.
What this means is, each slot can handle a max of 1GB per stick. So 4 sticks is for GB's.
As for hard drive size, this is usually a limit of the OS and not really a problem since earlier windows days. You should be able to put a fairly large hard drive in there, just make sure the right cables are used. This board uses SATA cables, so your hard drive must be SATA not PATA.
Hope this helps.
Caid.
Posted on Dec 31, 2008
  • CaidJ Jan 06, 2009
    Once again, the hard drive shouldn't be limited by XP. You should be able to put a lot in there, a bit hard drive, should be ok.
    As for DDR1 or DDR2 I am not sure. Here is the official spec sheet from intel. http://www.intel.com/design/motherbd/ag/...
    They don't list the ram types as 1 or 2, they list them in specific numbers.
    I hope that helps.
    Just as a side note, this motherboard looks a bit older, and supports some older ram types. I have a feeling that it might not support newer ram types. Keep that in mind when you're purchasing ram for it.
    Caid.
My celeron r 915 1.7ghz is working too slow
To speed up your processor, you need to take some load off of it. Search through all your TSR programs and services to remove things you do not need or want.
Another way to help your processor is to add more RAM to your motherboard. Find out what is the maximum you can put on the motherboard and load it up.
You can also reduce the size of your swap file. That would reduce the amount of time your processor is downloading data from your hard drive. A real processor time waster.
Aug 24, 2013 | Intel Celeron, 2.93 GHz Celeron D...
I WANT TO UPGRADE MY SYSTEM .MY SYSTEM SPECIFICATIONS ARE: RAM: 512MB DDR2 SAMSUNG RAM HARD DISK: 80 GB PROCESSOR : INTEL PENTIUM 4 @ 3.20GHZ CAN YOU SUGGEST ME THE BEST OPTIONS THAT CAN SUIT THIS...
The frist thing to upgrade is the amount of RAM you have. All the newer Microsoft opering system requier at lease 1Gigabyte of Ram to work.. After that consider upgrading you hard disk drive.
Mar 24, 2012 | Intel Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
Max Size for Intel 865g
hi,
500GB is the maximum hard disk size for 865G motherboard.
Sep 20, 2009 | Intel 865G Motherboard
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
Upgrade Hard Disk Space
Hard disk and ram are totally different. You can put whatever sixze hard drive you want to on your system. Just jumper it as the slave drive. As for the RAM, go to tigerdirect.com and use their ram calculator for your SPECIFIC computer.
Jan 26, 2009 | Mercury P4VM800M7 Motherboard
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Upgrade
used asus p5pe socket 775 ddr ram..ok intel based mother board
Feb 08, 2008 | VIA P4X266 PE11-L Motherboard
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
509 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
