Question about iLO 2600 Television
ILO 26" LCD
I have this line that runs across my screen. any idea on how to fix it. It is very thin but noticable.
The only thing that comes to mind is a similar, but not exact problem I recently had. If you're using cable try to change out the cord and/or the splitter with a higher grade. You can check to see if either of these is the problem by hooking the tv up to the original cord coming into the house. If the line disappears you know it's somewhere in the connections.
Posted on Jun 19, 2007
How do I fix my 50"Samsung led t.v?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 17, 2016 | Samsung UN50EH5300 - 50" 5 Series...
Thin vertical line on LCD tv
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | iLO V27DMBX Television
I have a 42" LCD
I do think the your pixels are dead or may be the screen has been moved or hit with something. I dont know how to fix it but you can try changing the screen if it has a warranty
Feb 10, 2011 | Toshiba Televison & Video
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
There is a vertical red line that runs down the screen on our Sanyo TV. It is just a thin line but it is annoying because you know it is there. Any suggestions?
thin lines are associated with the connection of the pixels on the screen in the grid. If its under warranty get it fixed before expiry as its not a cheap fix.
Red lines are not convergence problems they are component problems so you cant adjust it out
Sep 13, 2009 | Sanyo DP26746 26 in. LCD Television
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Two light lines have just appeared
Your driver transistors are failing on those "Rows" of Pixels.. a common problem .. you could try "Pixel Reviver" software from here http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor see if that helps.. but it possibly is on the way out sorry..
May 22, 2007 | Sony SDM-HS75/B 17" LCD Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Televison & Video Logo
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
