Question about Indesit W 123 Front Load Washer
F-01 when it switches on, door locks straight away and then it makes a pumping noise and shows f-01 the only way to switch it off is by the wall.
  • Indesit Master
  • 3,463 Answers
F01 is indicating a short circuit motor triac, this is part of the control that controls the main motor. You have no option but to call Hotpoint (indesit) and book an engineer as it is something you can't do youself..Sorry , but that is your course of action.only
Plz rate my solution.
Thanks
Posted on Dec 29, 2008
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
NEXXT 300 FRONT LOAD WASHER SHOWS CODE E-01. DOOR WILL NOT OPEN AND THE HOW TO VIDEOS ARE ALL FOR MACHINES WITH COMPLETELY ROUND DOORS, THIS MACHINE DOOR HAS LARGE PORT HOLE IN A SORT OF THUMB SHAPED DOOR....
Have you tried powering off/disconnecting the power cord to the wall? Then try plugging it in and turning it on - it may revert to the default "unlocked door" state.
If the door is still locked there is generally a manual release that is accessed from a panel that you need to remove below the door lock mechanism. On my model I had to prop up the front of the washer to access the screws - the panel runs the full width of the washer in my case. Once the panel is removed you should find a plastic rod hanging down from the lock that you pull down on - and then open the door at the same time.
My door lock mechanism went bad on my Bosch washer and I had to replace it - but it did give me a warning (though I wasn't sure what was going on at first). My washer makes a loud noise when locking/unlocking the door - that's the solenoid engaging/dis-engaging. In my case it started making that noise more than just once - first a couple of times, then 3 or 4, then finally about 8 times before it gave up the ghost a week or so later.
There are a bunch of videos online that are generic in nature about how to replace that door locks on front load washers... but essentially you need to remove the retaining spring/wire that is holding the rubber seal onto the washer opening, then peel the rubber seal away from the washer to allow access to the door lock mechanism. Replace and reverse the process.
Feb 22, 2015 | Bosch Washing Machines
2005 pontiac montana door switch locks all the doors but doesn't open any
Most likely problem is a faulty connection behind the door lock ,could be a metal connecting rod come away or a electrical switch ,now iam not familar with this american vehicle so i couldnt tell you exactly how it works ,if had the door panel off i tell you straight away but from spain its a slightly bit difficult ,so ask a local mechanic with experiance of this vehicle to have a look for you
Nov 16, 2013 | Pontiac Montana Cars & Trucks
Central Locking
i would start by checking the switch on that door. it sounds like the switch on the lock asm. my be getting stuck.
Jun 09, 2013 | Cars & Trucks
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
Whirlpool Duet washer will not start . Hear a clicking noise then receive DL F fault
The clicking sound is coming from the door lock/switch assembly trying to lock the door but it cannot. After six trials, the error code "FdL" shows up on the display. Press PAUSE/CANCEL button twice to clear it.
The only way to fix the problem is by replacing the door lock/switch assembly with part numer 8181700 and costs about $40-$55. Some vendors listed it as part number 1094190 or PS972231. Below is the replacement procedure.
Door Lock/Switch Replacement Procedure
  1. Unplug the machine and open the door.
  2. Stretch the retainer spring of the seal boot retaining hoop then remove it. The seal boot is the gray rubber around the door opening. The retaining spring is located at the bottom of the door opening. The door lock/switch assembly is located on the right side of the door opening.
  3. Ease the part of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot because it will cause water to leak from the tub.
  4. Remove the three screws securing the door lock/switch assembly to the front panel.
  5. Lift the door lock/switch assembly and pull it away from the front panel then pull it out of the machine.
  6. Disconnect the wiring harness connector and connect the new door lock/switch assembly.
  7. Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 20, 2010 | Whirlpool GHW9150 Duet Washer
When activating locking, it unlock straight away
replace the master door lock switch.
Sep 17, 2009 | 2001 Ford Focus
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
Kenmore Refrig. door water disapenser
check the switch on the water despensor , solinoid valve or the water supply to the fridge
Apr 13, 2009 | Refrigerators
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Indesit W 123 Front Load Washer Logo
364 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
