Question about Belkin (F5D7230-4) Router (587009)
I have forgot my wep password for my router
Is there any way that you could reset the the router and put a new password in if you can send me a message to my email address
  • 827 Answers
Type into the internet url address bar. This will take you to your router's domain page. From there, Restore Factory Settings. Wait until the process has completed and it says you can connect to the internet. Then go to Security menu and enable WEP or WPA and it'll ask you to put a new password in.
Write it down somewhere safe!
Good Luck :)
Chris (ziraffa)
Posted on Dec 29, 2008
Forgot my verizon actiontec router password
wifi password or the password for logging into the router settings? If you do a factory reset on the router it will put all settings back to default settings, the default password can normally be found on a sticker on the side or bottom of router. it will say "WEP" or "WPA2 key". you factory reset the router by holding down a red button (inside of a hole) on the back of the router for 12+ seconds while its still powered on.
Jan 08, 2014 | Actiontec Computers & Internet
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
I forgot my wep key and router username/password
Use first the default username and password according to your router's manual. If it doesn't work reset the router. Look for the reset pin hole on the back of the router. Press and hold it down for 1 seconds.
After that use the default username and password for sure this time it will work. As soon as you are able to access the configuration page of your router please setup a new WEP key to keep you network secured.
May 21, 2011 | Linksys WRT160N Wireless Router
Forgot the wep key code.
If you forgot the wep key to your internet your best solution would be to reset your router and restore all of your settings to their default value. There should be a rest hole on the back of the router. simply hold down the reset button and then log back into the router using the default ip address (try either or and the default username and password. Once you do that you will have to go and set all of your values again such as your network name and your new wep password.
Hope this helps!!
Apr 27, 2011 | D-Link Wireless N 150 Home Router 4Port...
Hello i just baught a playstion3 how do i reset my router cause i forgot the password for the wpa key
If you forgot WEP key for your router you just need to log into the router and look up the key. If you do not know the Admin password for your router then you will have to do a hard reset of the router.
The links below are examples of what steps you woudl need to go through to look up the WEP info on your router.
How to setup WEP on a Linksys Wireless-G Broadband Router
How to setup WEP on a Belkin N1 Wireless Router
How to setup WEP on an SMCD3GN Wireless Cable Modem Gateway
If you have any questions or problems let me know the make and model of your router so I can better help you.
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
I forgot the password a i want to know how to reset the router so i can put a new password in
For reset router press RESET button for 10 seconds it is in back side of router.Connect your router to computer with ethernet cable then you can access it with following default link. or or or If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then WEP security change the password and save settings.Then restart router then you can connect wifi with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | D-Link GamerLounge DGL-4300 Router...
I have a new laptop but forgot my password for my linksys WAG200G wireless router so have done a hard reset but now I can't get any laptops to connect.I have a 26 digit code but not sure if need anything...
as i know, if you have done the hard reset linksys will reset to default setting in this case your 26 digit WEP code no longer effect. you should login to admin to set your setting. may be you can read the manual again or see support/WAG200G
May 13, 2010 | Linksys WAG200G Router
I have a t-mobile linksys router. old computers and phone work fine. new laptop doesn't because i forgot or don't know the password for the router. is there a way to find this?
Connect your router to computer with ethernet cable.
Then you can access it with following defaults link.
type user as "admin" and password as "admin" or blank or "password".
Then you can see configuration of router.
Click on wireless and then wep security there is wep code it is your password to connect wifi.If it in * or # format then you need to set new add new WEP code then save settings it is your new password for connect internet.
Let me know if you need further assistance.Thanks for uisng FixYa.
Dec 07, 2009 | Linksys Wireless-G WRT54G Router
Forgot D-Link 1310 wireless password - how do I retrieve it
What password? Are you referring to the WEP or WPA-PSK password? If yes, I would like to inform you that no one could give you the exact WEP or WPA key. Even if you check the utility of the router.
What you need to do is to reset the router to factory default and then reconfigure the router. That's the only way that you could do in order to set a new password.
Have a good evening!
Aug 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Resetting WEP Password on Netgear WGT624
If you hold the reset pin in for more than ten seconds(I always count to 15) it will do a Factory reset...this will set all back to factory specs
Then you can set a new wep as well as an admin password
Jan 27, 2009 | NetGear WGT624 Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
114 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
