Question about Honeywell Programmable Thermostat Heater
Same thermostat issue
Hi there im having the same problem with my timer and control box ie green light and a flashing red light , i was wondering if you had managed to solve the problem as every route i take seems to run into a dead end
many thanks Lee
  • Croda74 Dec 29, 2008
    i have the quick user guide only and it only brushes the surface of how too solve it , so if you would be so kind to post the relevant section i would be hughly grateful
    thanks Lee
Do you have the instrustion manual i sorted it with that only problem it was at my dads so the manual is there if you are still having problems i can get it tomorrow and write the instructions in
Posted on Dec 29, 2008
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
All lights flashing all of the time plus fridge could be colder
check air control knob and vent and cold control thermostat also known as defrost timer. as for the lites falshing Im have no clue sorry other than a bad control board
Mar 11, 2015 | Refrigerators
Im trying to install a Utilitech 0192773 self adjusting wall timer. It has four wires, black(hot), red(hot), white(neutral) and green(ground). I have a standard three light switch plate(outside light,entry...
Thank you for clear description of wiring, switches, and for including timer model number.
1) Open following link for ez programming and wiring for Utilitec.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
2) Your single-pole switch has 2 wires.
0192773 replaces single-pole switch only.
Black wire that connects each of the switches is Hot wire: connect this wire to timer Black wire.
Other black wire that connects to switch goes to load: connect this wire to timer red wire.
Timer white wire connects to white wires that are covered with wire nut.
Timer green connects to bare ground wire.
3) How to connect stranded wire and solid wire
http://waterheatertimer.org/How-to-twist-electric-wire.html#stranded
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic & Self-Adjusting Wall Switch...
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
Hi, my gran has an old toshiba 2987DB model And for some reason a timer has set itself and We now can't get the tv to come on. There is a red light with a green flashing light underneath it. We've...
I wonder if you can help.
I have a 29" Toshiba TV Model 2987DB.
One of the speaker boxes contained within the surround speaker unfortunately no longer works and I'm trying to obtain another speaker box. The details are its an 8 ohm 5 watt no. SPK-1276 SGP 23351002.
If you can help that would be greatly appreciated.
Regards
Ian Willson
Mob; 07766396233
Oct 04, 2010 | Toshiba Televison & Video
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hello, I have 2 black wires coming from the junction box, and a copper ground wire. I connected the green wire to the ground. Where do I connect the red, white, and black wires?
The timer should have red, black,blue and green wires. (no white?) If you have only the two black wires coming from junction box, then connect green to ground like you did. Connect the incoming black (HOT) to the black wire on the timer.connect the outgoing (to the light) to the blue wire on the timer. Cap of with wire nut the red wire. This is for a single pole switch installation (Only switch for the light) If this is for a 3-way control (where you have 2 or more switches) then you use the red.
Aug 05, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Heating & Cooling Logo
177 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
