Question about Audiovox VOD808 8-Inch Flipdown Screen LCD TV/Video Monitor w/built-in DVD Player (VO-D808, VOD-808,...
Picture is jumping, cannot watch DVD's
My dvd player has suddenly stopped working. It plays but the whole time the screen has black and white lines through it and it appears to be kind of jumping on the screen. What could be wrong?
0 characters
1 Points
Every time i play the cd player it jumps back to the radio
Did you check if the DVD disk you are trying to play is actually playable? Mabe the player can't read the disk so reboots to radio. Also, you should try with another DVD disk
If disk is ok, recheck your original setup options, but I'm quite sure that it's some electronic failure of your device. Simply should not make sense some hidden option to play radio wnen you select the DVD player.
So your final optin probably should de take your device to repair service. Look at your original warranty for nearest authorized repair service, even if warranty has expired.
Oct 18, 2015 | Clarion NX501 Navigation system with DVD...
My jensen dvd player mvb85
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Feb 06, 2008 | Jensen 8.5" Overhead DVD Player Package...
Dvd plays audio when dvd inserted but no video, screen says no video signal and stop watch video
I would suggest replacement of the lense if no change then change the video card ( video section )it might be faulty. good luck .
Jan 22, 2011 | T-View T-6500HR 6.5 in. Car Monitor
What can i do to wacht dvds?
you must have connected the safety feature to the hand brake.
this disconnects the dvd from working until the hand brake is applied. you will need to attatch this wire to a ground connection to enable it to be played while moving
Apr 06, 2010 | XO Vision GX1046 10.4 in. Car Monitor
MY in dash dvd player with flip open screen doesn't open
in dash flip tv dosent come allthe way out
Oct 29, 2009 | Car Video Monitors
DVD player car screen plays dvd in B/W , navigation in color
try checking the color system if its ntsc or pal
Jul 11, 2009 | Car Video Monitors
Dvd player in van no longer has sound
hi i have a toyota van and i have dvd play in it...the dvd player sound works with the radio station but i for got the cnu help what channel is it spousd to be....write back plzzz
Jul 18, 2008 | Eiger Vision AV-1301 Car Monitor
Are u gettn a pic on ya dvd...i cant
if its a in dash dvdplayer u have to put the pink wire to an earth its for safety so u dont watch it while u are driving if thats not dune it can stop the picture
Apr 24, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
Screen problem
use your remote and change to AV1 sys 1
Jan 03, 2008 | Legacy LSWR82IR 8 in. Car Monitor
Vertical Hold doesn't Hold
This would denote some kind of vertical sync problem. I would begin by checking the vert sync circuitry. To do this you will have to have an Oscilloscope, and DVD containing a steady-state picture. The oscilloscope is used to measure the vertical sync rate and the vertical sync pulses. Taking into mind that ther is a video signal present but it is in the black range. If you do not have an oscilloscope it makes troubleshooting this hard. in any event you will also need a schematic to see what waveforms you should be seeing. If you do not have a background in electronics you may have to have someone who does look at this unit.
Sep 19, 2007 | Rosen CV1010N Car Monitor
Audiovox VOD808 8-Inch Flipdown Screen LCD TV/Video Monitor w/built-in DVD Player (VO-D808, VOD-808,... Logo
32 people viewed this question
Top Audiovox Car Video Monitors Experts
isaac johny
isaac johny
Jaime Hernandez
Richard Lilja
Richard Lilja
Are you an Audiovox Car Video Monitor Expert? Answer questions, earn points and help others
