Canon MP 600 cartrige recognition
Printer does not recognise the yellow and cyan cartiges. refitting used to solve the problem but not anymore.
Please can you assit us with the issue at hand.
  • vdlingen Dec 29, 2008
    all contacts cleaned, electrical as well as ink
  • Thomas F. Schneider May 11, 2010
    Have you tried to clean the electricial contacts on the cartiges and pins that they contact with an pencil eracer then reinstall?
    President:
  • 8,637 Answers
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Canon pro9000 mrk2 printer wont recognise yellow cart cli8 but if I lift out the cyan cart it will recognise the yellow until i fully seat the cyan back in the holder again
you do get this with a lot of canon printers its nor-manly the black, make shore you have the prober canon cart because some of the copy,s don't match the pin,s on the printer also clean the pin,s on the printer, that the cart fit,s back to with a cue tip but be care full not to hard as this my damage the pin,s which my be the cause. I would swap any way to a chip epson the ink,s cheaper
Nov 01, 2011 | Canon PIXMA Pro9000 Printer
Can you tell me which cartiges I need for my mx700 cannon printer,fax,copier
The Canon mx700 printer uses four (4) cartridges: PGI-5 (Black), CLI-8 (Cyan), CLI-8 (Magenta), and CLI-8 (Yellow). The colors all have the same cartridge number so you will have to specify which one you want.
I hope this helps! Good luck!
Feb 15, 2011 | Office Equipment & Supplies
Cartrige error 1203, what do I do to solve this problem?
It seems your courtige do'nt support in your printer. To continu your printing you need to replace ink cartige. In older cartige you may try the following tecnique:
1. Open your unsupported in cartige.
2. Take a pice of tissue paper and wip smothly both the connector plate and cartige head.
thank you.
Aug 17, 2010 | Lexmark X7170 All-In-One InkJet Printer
Yellow ink is not printing properly
i think your cartige yellow ink had finished or dried up what u can do is refill yellow ink or dip cartige into hot water.... and clean it nicely it works
May 20, 2009 | Canon Pixma iP4500 InkJet Printer
Wont print ANYTHING if ONE ink cartrige is out
need to replace all to! some printers are like that wont print unless all inks are full and inplace!
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Mp 600
yes it is possible.
when you give the print command the print dialog box appears select the properties and select one of the options print black and white or print in greyscale.
Apr 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon Smart base MPC 400 Printer
This printer needs these cartridges: -
1. (BCI-3eB) Black Ink Cartridge,
2. (BCI-3eC) Cyan Ink Cartridge
3. (BCI-3eM) Magenta Ink Cartridge
4. (BCI-3eY) Yellow Ink Cartridge
I think you need to clean your cartridge connectors with alchohol and retry.
Nov 21, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Cyan ink tank not recognised
I phoned Canon Tech Support Center this morning. They had me replace the ink tank giving me the U150 error code and are sending me a replacement tank. HOPEFULLY this will solve the problem.
Oct 27, 2007 | Canon PIXMA MP510 All-In-One InkJet...
jasbo
jasbo
