Question about Denon AVR-3805 Receiver
Wii, Family Ski, Denon 3805, screen flashes to black
My wii is connected to my Denon via a component cable and my TV to my denon via another component cable. The wii menu's are fine and so are wii play and wii sports. If I play Family Ski it flashes to black then after a few seconds returns to the game; it is almost if the sign is lost and then the TV finds it again.
If I use the composite wii cable through the Denon I get the black screen flashes in the menus and the other games.
Has anyone had similar problems; is there a way round this?
  • Anonymous Mar 27, 2009
    I have a similar set up going from the Wii to a Pioneer Receiver and then to the TV vis an HDMI cable.
5 Suggested Answers
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-3805
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • 4 Answers
SOURCE: connecting PS3 to Denon AVR-3805
refer to manual
http://www.playstation.com/manual/pdf/PS3-01-1.0_2.pdf
think you can use AV multi out connector
Posted on Nov 25, 2008
petraman7
  • 1175 Answers
SOURCE: how to connect Wii to Denon AVR 3805
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-3805&imageField.x=10&imageField.y=9
cut and paste the link.
All the info you need should be there
Posted on Jan 19, 2009
  • 119 Answers
SOURCE: Describe your Denon AVR-3805 7.1 Channels RecI
There is a button on the front of the unit under Input its a mode button press this button to select auto that should give you sound
Posted on Aug 02, 2009
mlapres
  • 757 Answers
SOURCE: I am trying to connect my wii to my denon avr-2802
After connecting the Wii cables, connect a video cable to the "monitor out" connection to a compatible input on the TV.
Posted on Feb 15, 2010
How to connect a walkman to a Denon AVR-3805
headphone jack cable to 2x RCA/phono (red & white) cable. Connect that to a spare input on the amp.
Sep 02, 2014 | Denon AVR-3805 Receiver
My denon avr 3805 has no hdmi ports. how do i connect my comcast cable box to it.
The only way would be component cables, and digital or analog audio cables. I believe there are HDMI to Component convertors as well.
May 12, 2014 | Denon AVR-3805 Receiver
I have a Sony Bravia XBR 4 LCD. I connected a RCA cable to my Denon 3805 monitor out and RCA to the Sony video 2 in.I want to set up the Denon using the Sony as a monitor to set up my speakers. The screen...
Make sure you didn't get the video line out confused with one of the audio lines.
If using composite video the connection should be yellow and the left and right
channels should be red and white
May 16, 2011 | Denon AVR-3805 Receiver
Wii to a AVR 1610 via DVR input
"A" (single) component cable? Really? Not composite?
The source determines the aspect ratio of the video. If you decide to change it, that's your choice but it isn't accurate. 4x3 is intended to be shown 4x3. A circle will be elongated if you stretch the image to fit the screen.
Disregarding the black bars, is the geometry of the image correct? If so, why can't you just go with it?
If you want to change how the TV treats it, you'll have to refer to the TV's manual and controls.
May 06, 2010 | Denon AVR-1707 Receiver
Connection problem with Denon 589 and direct tv
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 08, 2009 | Denon AVR588 Receiver
How to connect Wii to Denon AVR 3805
Jan 10, 2009 | Denon AVR-3805 Receiver
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Denon AVR-3805 Receiver Logo
271 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
