Question about Dryers
Dryer doesnt seem to be getting hot as it usually does
My TCS 65w dryer seems not to be getting hot when drying could there be a thermostat issue
  • angie_joh959 Dec 29, 2008
    Thanks for that, its probably what i meant!!. There is some heat there but i know it didnt seem right. I tried on both settings. I will get my bro to order me a new one.
    New Friend:
We had a similar problem with our dryer just last month. It would spin and turn on, but no heat. It turned out not to be anything wrong with the heating element--it was a tiny electrical part that had malfunctioned.
Anyway, I would recommend calling in a professional if you've already cleaned your dryer and still can't get it to work. That could save you a lot of time and money in the end.
Violet Campbell ' http://www.ayersappliancerepair.net/appliance-repair-services/
Posted on Jun 09, 2014
    President:
  • 2,692 Answers
Have you have tried it on time on the hot setting with the same result? If yes then it is a heat element issue, not thermostat.
Posted on Dec 29, 2008
The dryer will turn off before the load is dry. Cleaned the vents and replaced the cycling thermostat with no success.
Look inside the drum, there is a little vent hols on the wall of drum, you need to clean those coz air cann't go throught that, behind that installed heater and that's why gets hot, safety thermostat of heater gets off.
Or you just need to go to the fan and clean it...
Nov 09, 2015 | GE Dryers
It doesnt seem to dry very well or takes a really long time
Zannusi Dryer TDS383W element gets Hot (glows)then cuts out after few seconds then if I wait for couple minutes and reset the clock to any set time the element glows hot again until inbuilt thermostats 'click' again cutting out the element,this process is continuous with or without the lid and ducting in place.
Feb 14, 2014 | Zanussi TD4112W Electric Dryer
Wdc1025 splendide all in one combo,the dryer doesnt seem to get hot enought to dry??help
Do the clothes eventually dry over a longer period time than usual? If so, there are 2 possible problems.
1. Your dryer vent is nearly clogged
2. If it is electric, then the heating element is going bad.
GOOD LUCK
Mr. Tin Man
Dec 19, 2010 | Washing Machines
We have an lg dle3777w dryer and it doesnt seem to get very hot to dry the clothing...it takes many cycles to get one load dry...any ideas???
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG DLE3777 Electric Dryer
My dryer is not getting hot consistantly. It will warm up then cool off - at times getting warm again. It seems to be doing this on auto-dry as well as timed dry. I changed the cycling thermostat, it...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer for whirlpool and Kenmore styles or try this troubleshooting a ge style gas dryer
Oct 03, 2010 | Maytag MDG3706A Gas Dryer
Dryer gets hot and turns off
Hello there:
A lot of the times the problem lies with in the Cycling thermostat that is going out Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly.and can make the dryer stop working after it is working for a given amount of time If so, you need to replace it.
Next is the The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
It overheats and shuts down due to a bad thermostate Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Sep 27, 2010 | Kitchen Ranges
GE DCXR463EA1WW that has stopped heating.
Probably a bad heating element. Sometimes one side will burn out before the other, so it takes a lot longer to dry. Then the other side burns out and it won't dry at all. Usually thermostats last longer than elements.
Jul 25, 2017 | Whirlpool GEW9200L Electric Dryer
Dryer takes 4-5 hours todry clothes dryer seems hot just not drying
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 08, 2009 | GE Dryers
Dryer (electric) seems to heat up initially, then cool off and not get hot enough to dry clothes. What is wrong?
Check the following areas thoroughly to address this issue.
1. Venting
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.(usually located inside the unit on the actual blower housing or inside the vent duct)
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 19, 2009 | Dryers
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
