Question about Frigidaire FGB24S5A Gas Single Oven
Having difficulty lighting the frigidaire oven/broiler
Sometimes it lights after a couple of attempts and others after many attempts. Sometimes it doesn't light at all.
  • Thomas F. Schneider May 11, 2010
    Have you tried cleaning and ajusting you spark igniator(sp)?
Your advice was excellent, thank you.
Posted on Dec 30, 2008
My Frigidaire gas oven won't light but broiler does light
Hello friend, thank you for your post!
From what you are describing it sounds like a potential issue with your control or pressure regulator within your Frigidaire oven. I would recommend seeking assistance from a professional for further help regarding the oven not lighting due to the gas.
If you need assistance connecting with a professional technician you can visit the manufacture's website for further help. -Matt
Oct 04, 2014 | Ovens
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven elements have power but do not heat up
Hello kyren1999 - If the broiler element and the top of the unit works, but just not the heating element, then you possibly have a bad bake element or connection. However, if you are experiencing other performance difficulties, then you may have a bad control board that needs to be replaced. Consult a professional for an accurate diagnosis.
Nov 23, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
Fridgedaire Oven burner sometimes doesn't light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
dddddddd76
May 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven will not light
The control panel behind the knobs is the most likely problem.
The heating element rarely fails.
Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
FGF374 - Broiler and Bake does not stay on
The flame sensor has to prove the flame to stay lit. When it fails, the valve closes.
Jul 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
CPES389AC3 - Frigidaire Gallery Oven - Element and broiler
The element has blown in the oven you will need to fit a new one,and possibly the broiler one as well.
Plz rate this solution.Thanks.
Dec 20, 2008 | Frigidaire FEB30S5DC Electric Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
192 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
