Want to cancell progressive scan settings
How can I restore my Panasonic SC-HT440 system to it's factory settings?
I thought my TV was progressive scan capable and I change the settings to that. Turns out the TV doesn't have progressive scan capabilites and now I can't see the video portion of DVD's.
Can't even see the menu to change things back. I have the same problem with a pioneer DV575K. I tried the stop button trick but there is no [≥10] key on my remote. Any ideas please
Restore Pioneer DV575K :I solved the problem myself thanks, googled for info and all it took was to press the standby/power key on the main unit (unit in stanby) while pressing the rewind button...zammo its fixed.
Many thanks
Posted on Dec 30, 2008
I am seeing two pictures that look like two screens. and the pictures are not coming in clear.
Sound like the unit might be in progressive scan mode and the tv cannot display it correctly. Try finding a button on the remote that says progressive scan and see if you can turn it off.
Jun 11, 2013 | Panasonic SC-HT650 System
The door will not close---ModeSC-HT440
comes from having the dvd or cd not laying flat in the tray..
or the mechanism is broken..
one or the other..
does the button work when it's empty?
Mar 24, 2008 | Televison & Video
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Mar 26, 2010 | Panasonic SC-HT730 System
Panasonic SC PT660 Theater w Samsung Plasma -No sound w/Aux Input
My best advice is to do a factory reset on the system and then set it up again like you did when you first installed it. Unless your daughter physically damaged cables, the system should work OK. It's no use trying to work out what she disconnected as that will take even longer than a factory reset.
May 27, 2017 | Panasonic SC-PT660 Theater System
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
Panasonic sc-ht440
Always be for ICs audio amplifiers damaged.
Apr 13, 2008 | Audio Players & Recorders
Hello fiddlehead,
Well, here is the procedure to reset the SC-HT440 . While unit is powered and stopped, select “DVD/CD” as the source. Press and hold [■] (Stop) button on the main unit and [≥10] key on the remote control until “Initialized” disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Since you mention that you can not see the menu on your TV's screen, then you won't be able to see the "initialized" disappear, so, give it a second try if the first fails or press and hold the keys for a little longer.
Let me know how this works for you.
cancerags
Jan 02, 2008 | Panasonic SC-HT440 System
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
