Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Tumble dryer not heating/drying
Hotpoint Aquarius CTD00
  • Hotpoint Master
  • 3,463 Answers
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Plz rate my solution
Posted on Dec 29, 2008
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My dryer not heatin up and dryin clothes hotpoint aquarius CTD00
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
We have a full video library on appliance repair video’s
Dec 30, 2009 | Hotpoint Dryers
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Plz rate my solution.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
