Question about Panasonic DMR-EH57 HDD Recorder Player
Gray backround around jpg
Vieuwing my jpg files then there there is also a grey background on the sides. In my menu I turned my grey backrond off. But the background is not turning black. How can I solve this?
Regard Eric
  • eric_hehenka Dec 31, 2008
    Shutting down does not help. But I will unplug maybe that will help. Thanks for the idee
  • eric_hehenka Jan 01, 2009
    Restarting does not help. complete power off neither.
    eric
  • 495 Answers
Try to restart your recorder player and then check if the problem still persists.
Posted on Dec 31, 2008
    Novelist:
  • 163 Answers
Try to reset your player.
  • ronny2051 Dec 31, 2008
    * Switch your player on without a disc in* Point the remote at the player and press 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 in that order
    * The player should then reset , if not, try the process again.
  • ronny2051 Jan 01, 2009
    take a try-- the blow procedure will reset your player and make your player region free......
    The region free hack procedure:
    * Login to the region free hack account (using Harmony client software)
    * Update your remote (this will wipe out existing setup)
    * Select the only device on the remote (the Panny device with the hack)
    * Switch your player on without a disc in the tray
    * Make sure the Panny is in DVD mode (not TV or Blu-ray - this is a DVD player hack!)
    * The player should then reset and be region free, if not, try the process again.
    §Looks like the profile will work with any Harmony remote... just accept the change of remote number when updating yours.
    Thanks for your question
How do i change the background on my dell 1018 mini laptop?
If the operating system is microsoft windows then
right click on the empty space on the screen
select property
a window titled "display property" should appear
select the tab: "desktop"
n middle of the right side there should be a button "browse"
after clicking on it a menu window for selection of background file should appear
use it to point to the background file you have
normally background file should be picture files: such ad "jpg", gif. bitmap files
Good luck
Mar 09, 2011 | Dell Inspiron Mini 10 Notebook
Tip
How to change your windows 8 Start menu background
1st go to the windows start menu,then go to the up right corner of the screen then a menu should come up,then select settings and then select personalization,then select a backround or use your backround on the desktop,stay on the background if you want a color only,select a color i you choose to stay on the background.Watch the video for more info
By Thedimond Gamer,About How to change your windows 8 Start menu background
on Aug 09, 2015 | Microsoft Windows 8.1 - Windows
I cant set a desktop backround for the hp mini laptop
You have windows 7 starter or vista starter i am guessing , which means there is no option for changing the background, it has been disabled.
It can be enabled though through various hacks
click on this
Stardock MyColors
download it and To use it, find a jpg wallpaper you like, then run Starter Wallpaper Changer as administrator (right click onb the file and click run as administrator). Select your jpg file, and change. Then log off, and log back in. Simple!
please vote if this was useful to you
Feb 23, 2011 | HP Mini 1000 Netbook
How do you get a customized backround from paint and make destop backround
Click on "Help and Support" from the start button and enter your issue.
Dec 30, 2010 | Acer Computers & Internet
Problem
in photoshop or MS word just increase the contrast of the image and all dirty gray background will disappear and if u need our technician support contact http://tinyurl.com/mtgjzz
Jun 22, 2009 | Xante CL30 HSE Laser Printer
Will not show or import jpeg or jpg files
You need to ensure that the background images are turned off in the entertainment menu first then insert disc or usb stick to show images.
May 02, 2009 | Car Audio & Video
Grye sides jpg
ake a try-- the below procedure will reset your player and make your player region free......
Jan 05, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Loading backgrounds from a usb device
YOU HAVE TO PUT IT IN STANDBY MODE THEN GO TO THE MENU AND HAVE THE USB PLUGED IN AND WHEN YOU VIEW IT IT WILL GIVE YOU THE OPTION TO SET BACKROUND
Nov 30, 2008 | Kenwood KVT-512 Car DVD Player
Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Jan 24, 2008 | Epson Perfection 1670 Flatbed Scanner
Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Oct 19, 2007 | Canon DR-1210C Scanner
Panasonic DMR-EH57 HDD Recorder Player Logo
18 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
