Question about Hotpoint TDC32 Electric Dryer
Thermostat keeps blowing on Hotpoint Aquarius dryer
The thermostat on my hotpoint aquarius dryer has blown AGAIN, this is the third time. Also the condenser is not filling properly with water, the light comes on and says it is full but it is no where near. Is this the cause of the thermostat blowing?
  • jobob_6947 Jan 12, 2009
    I did all of the things suggested but the condenser is still not collecting any water. i have changed the thermostat yet again but am worried that this will blow again as the condenser is not filling with water. Any other ideas?
  • Hotpoint Master
  • 3,463 Answers
Remove the filter completely from the bottom left of m/c
Wash out thoroughly under running water.
Reach in with your hand and clear any fluff and gunge you can find there.
At the rear of the filter housing there is a small drainage hole that blocks up.get a plastic bag tie or similar and poke it clear. Also there is a float chamber and some times the float sticks, this being the case , then it involves a complete strip down to clear prob.
Hope this helps
Plz rate solution
.Thanks.
Posted on Dec 29, 2008
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
Help! hotpoint aquarius condenser dryer
More than likely thermostat or heater.
Located at rear of dryer behind removeable panel, you will need a meter to test them.
Jan 28, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius dryer is not got any heat
Most likely reason is failure of thermostat/s or heater element.
As you do not specify model, Ir is difficult to tell you exactly where to locate them, but generally speaking they are at the rear of the dryer.
Hope this helps.
Jan 12, 2010 | Hotpoint Dryers
I HAVE A HOTPOINT AQUARIUS WD62 WASHER DRYER. THE DRYER FAN TURNS ON BUT DOES NOT HAVE ANY HEAT COMING THROUGH, ONLY BLOWING COLD. CAN YOU SUGGEST WHAT NEEDS CHANGING? THANKS - RICHARD S
It will be a faulty thermostat or element more than likely, or a broken wire.
Remove top cover, and you will see the heater manifold over to the right side, there you will see the element and thermostats.
You will need a meter to test them.
Hope this helps.
Jan 10, 2010 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius dryer
The t-stats have blown.. these are located on the top of the heater on top of the drum.. To check to see if their blown check the continuity if they are blown then there will be no continuity ... They come in a pair and are easily replaced.. All you have to do is take off the lid...
Nov 14, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint TDC32 Electric Dryer Logo
440 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
