Question about Nokia 6820
How do i open?
I got a ton of dirt covering my screen but its all on the inside of the cover... how do I open it in a non violent manner?
  • Waggygee Gee
    Waggygee Gee Apr 28, 2007
    no sweat mate...
No... im a DIY person. No way im gona pay for sumin like dis
Posted on Apr 28, 2007
  • 43 Answers
Hi To clear the inside dirt from your mobil cover you need to open that cover gently and then you can can clean it with cotton and again put the cover back > i recommend that you should go to any mobil store and in front of your presence you can tell the person to do it ,,,it will not charge you much money and also it will reduce the risk factor Good Luck
  • gunjan malhotra
    gunjan malhotra Apr 28, 2007
    ok but i tried to help you
How to clean the magenta toner sensor on a canon imagerunner c5255 copier
Step 1Turn off and unplug your Canon copier. Put on a pair of latex or work gloves to keep toner and debris off of your hands. Cover a table, desk or other surface with three to four sheets of newspaper to protect the surface from spilled toner Step 2Open your copier's toner cartridge door on the front or top of the device and remove the toner cartridge. The cartridge contains the drum as part of its unit. Lay a flannel cloth onto the newspaper-covered table, desk or other surface and then shake the toner cartridge gently above the cloth to coat the cloth lightly with ton
Place the cartridge upside down on the newspaper-covered surface and open the drum's shutter door, which contains hinges. Rotate the drum using the spindle on the side and wipe the drum's surface with the toner-covered flannel cloth to remove any dust, dirt and caked-on debris. The drum only rotates in one direction. Work quickly so as not to expose the drum to light. Artificial and natural light can damage the drum's surfac Step 4Continue rotating and wiping the drum's surface until it is free of any debris and dirt. Close the drum's shutter door and reinstall the cartridge back in your Canon copier.
Sep 28, 2016 | Canon Office Equipment & Supplies
Why porsche cayenne 2009 reverse camera cover is not opening
Is the camera activating? Is the screen going completely black or do you see the measurement marks on the screen when putting it in reverse? Might be a blown fuse, faulty power wire to the camera or simply that the cover is physically stuck by dirt or something.
Aug 17, 2014 | 2009 Porsche Cayenne GTS
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
Dvd will not come out of player
YOU HAVE TO REMOVE COVER, SCREWS AT BACK AND BOTTOM,PRY OFF COVER AND REMOVE,,,YOU MIGHT HAVE TO HOLD OPEN LOADING DOOR ON FRONT ,INSIDE YOU SEE OPENING OVER DISC LIFT UP DISC AND PUSH OUT FRONT DOOR, THEN REASSEMBLE SAME MANNER YOU DID TO OPEN
Feb 18, 2012 | 2005 Buick Terraza
I hv just purchase LG KM555 and the problem is yesterday by chance my finger touches some icon and the loading took place suddenly the screen became blue and was not able to get out of it and finally we...
The blue screen is one of many weakness of this unit. This result from Maximum application, low memory, full inbox, long hours of using WiFi and many more. The only thing I know to rectify that is to restart,, which is a bit annoying. So, use it caution and care because its not a HEAVY DUTY type of phone.
For the plastic cover or screen protector, buy a specific protector for your that phone. The reason is that there's a part on your screen that serves as SENSOR (Near the LG symbol, right side) . That sensor is used to prevent accidental taps during call. Even a transparent plastic will reduce its sensitivity.
Jan 25, 2011 | LG KM555 Cell Phone
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Need to remove screen cover
you have to remove the back of the tv to clean the inside screen.
Apr 29, 2009 | Toshiba 57H82 57" Rear Projection...
Lens (lens cover?) only opens halfway
Hmm, this has happened to me too now. And just like the previous two posters it happened to me once before, but after switching it on and off a couple of times it corrected itself.
Now, about a month later, it has happened again. And this time it doesn't seem like it's going to open fully any more. Out of interest how long have others had their camera before this happened? How many photos had they taken?
Bobster
Jul 15, 2008 | Fuji FinePix F10 Digital Camera
Dirt on the inside screen
Usually the best way is to remove the top back cover and clean the inside of the screen with a clean, dry cloth, but be careful because the mirror is mounted on the inside of the top back cover.
Jun 21, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Nokia 6820 Logo
47 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
