Question about LG KU990 Viewty
My LG Cookie resets every time i switch it off.
Every time i turn my phone off overnight, it resets all my settings when i turn it back on. I lose all text messages and everythings goes back to default including ring tones etc.
  • 1 more comment
  • keeleyt Dec 29, 2008
    my phone LG Cookie resets itself everytime i turn it off. Can i do anthing or do i need to return to shop
    how do iupdate firmware
    Thank you it will be taken back to the shop tommorrow
  • 4,889 Answers
A known issue with the cookie. The cause of this is believed to be a firmware issue that master resets the phone everytime you turn it off. I would try to update the phone with the latest firmware and see if this resolves the issue. Please post back if you have trouble finding instructions on updating the firmware. However if the firmware update does not work then this is probably an issue with the CMOS chip on the phone and it is not user servicable. Contact LG for repair/replacement as ginko and others have suggested.
Posted on Dec 29, 2008
  • eagle338
    eagle338 Dec 29, 2008
    You will have download the LG PC suite to sync your phone with you PC. After that select connection type. I would recommend USB as Bluetooth will screw up the phone if it disconnects during the upgrade. After that you will have to just click on the update software option usually found in the tools menu. The in-built help file contains detailed instructions on upgrading the firmware. Be sure to follow them carefully. LG is a bit too stingy as far as the updates are concerned so if this is the case with your phone as well run to your nearest LG store for a replacement.
  • 916 Answers
This is a defective phone model if you call LG they will replace it for you.  You can reach them at  LG Customer Care Center: 1-800-793-8896 Send an e-mail: customerservice@lge.com
    Master:
  • 413 Answers
You might have got a bad sim card
    Genius:
  • 1,011 Answers
Sir,
Take the battery out of the phone and lay the flat side down to a flat surface and try to spin the battery. If the battery starts to spin(without alot of effort) it shows the battery is starting to swell and is bad.
Also make sure you have the latest version of the firmware.
It is the defective model of phone, i searched the review in the internet, most of the peoples have same problem so try to better replace the phone, if u have warranty....
thanks
good luck
    President:
  • 2,110 Answers
It seems that ur memory card have some problem..try to change it..
  • 6,487 Answers
This is a software problem on your phone, what you can do here is to try doing a software update on this unit and that should fix the problem if not a repair or replacement is better if this is still under warranty,,,,
  • LG Master
  • 19,396 Answers
That means that the internal battery myst be replaced, also ensure the connection to power is fine.
  • Ginko
    Ginko Dec 29, 2008
    Hi, I can see the problem was concerning an LG Cookie (I-Phone Nano), and not t.he phone selected in title.
    In this case the problem is slightly different.
    If when you turn the LG Cookie, there is no battery charge, then the internal battery must be replaced.
    If there is charge, but the phone resets, that can be a short or a fault on the on switch, or a again, a short on the internal battery wiring, that resets the phone to factory each time you start.
    Also a defective memory card can cause the phone to lose all data , try a different memory card.
    The phone must be new, if all the bove do not fix the problem, call the phone number listed on the manual to get the phone replaced.
  • Ginko
    Ginko Dec 29, 2008
    Hi there, this appear to be a factory defect on LG cookie.
    Try replacing mem card, and performing a reset from setting menu, this won't probably work, as phone is defective.
    LG will replace the phone.
    See here for more user with the same problem, defective phones had been replaced.
    LG Cookie phone master resets when turning off & on? - Yahoo! Answers -
    Top Expert:
  • LG Master
  • 78,267 Answers
Are u saying the power is completely off to the phone? if so you are erasing the data because the keep alive memory is most likely volatile, which means it must remain in standby mode to retain owner settings.
  • yadayada
    yadayada Dec 29, 2008
    unless the system has a USB port u can't update the firmware, and firmware would not cause this problem, u did not answer my question about the power to the phone so the answer must be that it does have a non volatile memory, in that case the unit must have a defect in a non-volitile memory chip, this is most likely the issue and replacing the phone is the best option.
Where is the master reset button on lg kp 500?
there is no master reset button on this type of phone,please follow this instruction
1. remove the sim card an turn the phone on.
2. on your home screen type 1809#*500# then select reset.
3. wait until the phone restart...
now your phone back to default...
or
go to settings > phone settings then reset... if a code is ask,type 0000 as it is the default code or enter if changed.
good luck...
Feb 22, 2012 | LG KP500 Cookie
Hai my lg kp500 cookie phone touch pad is not working please send any solution
First of all remove the battery and the memory card from the phone. Use a hair dryer to warm up the battery compartment so as to warm up the set lightly. Now replace only the battery after about 15 minutes back into the phone and switch on. If the phone boots up and comes alive with a touch pad working, then reset phone to factory settings, connect your phone to PC to have a virus scan . Also now have your memory card scanned for virus, remove files and format.
If however the fault stays then you might have to contact Samsung to have the software reinstalled.
Check and get support from this link:
http://www.lg.com/uk/support/product/support-product-profile.jsp?
Jul 13, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
Cookie wont start up, stuck on lg logo then restarts itself again.
You need to make a soft reset or even a hard reset to your phone.
Soft reset:
For that, you need to know the ResetCode (usually 0000 if you don't change it):
Go to Setting - Phone Settings - Reset Settings - press ResetCode - Confirm
Hard Reset:
Dial 1809#*500# and choose Factory reset.
WARNING!: There will be no supplementary interrogation about if you continue or not! Besides this, performing hard reset, you will lose all data stored on internal phone memory. Be sure to save any unsaved data within a running application before performing a hard reset.
Jun 25, 2011 | Cell Phones
I dont know the reset password of my lg cookie phone
When you have some problems with your lg secret, Do you know how to hard reset or factory reset the lg secret?
You can go to LG Secret's "Settings", then "reset settings", the reset code of the LG Secret was just 0000 (4 x zero). This reset the LG Secret phone, although i backed everything up i didnt lose any files but all the menus, themes etc were set back to default.
for more go to lg site http://www.lg-phones.org/category/lg-secret-info
Feb 28, 2011 | Cell Phones
Lg cookie keeps freezing
The "refurbishment" was cosmetic, not functional.
Sep 05, 2017 | LG KP500 Cookie black on T-Mobile U-Fix...
Lg cookie freezes when memory card inserted
hi format your memory card through the phone it will set it to your phones settings.
Mar 30, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LG COOKIE KP500 WONT SWITCH ON !
If you can go to LG Service Center the only solution in your problem is to update the software of your lg cookie. Because I have done it and its working good.
Mar 04, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LG KU990 Viewty Logo
15 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
