Question about Dryers
Dryer motor has trouble starting
It's a Whirlpool LGQ8858HQ1 gas dryer. Recently, for all but the lightest loads, when we start it it makes some odd noises, then it shuts off for a couple minutes. Next, it attempts to start up again, and either kicks on correctly and works fine for the rest of the cycle, or makes the noises again and turns off for a few minutes in another repeat of the process. We've had to reduce the load by about half to get it to work.
I'm guessing there's a thermal limiting switch or something that's tripping due to excess load on the motor. The question is, what do I need to replace? Motor? Switch? Something else?
I do have a new belt/roller kit that has not been installed yet (dryer was squealing a month or two ago but that stopped and I was too lazy to proceed with parts swap).
Suggestions for how to proceed?
Thanks in advance!
Marc
  • magoldst Jan 04, 2009
    Yeah, over the past weekend I swapped the motor. While I was at it I put in the parts from the belt/roller/idler pulley kit that I had on hand.
    The old motor could hardly be turned by hand, whereas the new one spins freely. I'm sure I'll save on electrical power usage with the new motor.
    The only snag in the job was that the blower wheel, attached via left-hand-screw threads, was impossible to get off. I tried all the tricks I found online, but the part started to crumble when I tried detatching it. The bushing with threads in it was actually so married to the screws on the motor shaft that even after I cut the wheel off, and removed the motor, and had full access to everything, I still couldn't get it off (I tried just for fun).
    After reassembling the dryer worked a treat for one load, then caught on something and made an awful smell before the thermal cutoff kicked in. Turns out the blower housing was full of junk. Nails, rocks, safety pins, you name it. Probably from the original owners! I hadn't noticed it before. I cleaned all that out junk and all is well now.
  • 91 Answers
Sounds like you are having or go to have a motor problem repl/ motor
Posted on Jan 04, 2009
Whirlpool gas dryer Model GGW9200LW0. tumbler will not start everything functions as usual but the motor makes a humming noise and the tumbler will not turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool GGW9200L Gas Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Dryer won't start, been using all day no problems. Go to load another load in, it lights up when I press start all I hear is a 'click' sound and then nothing. All lights stay on just like it's ready to...
heatman101
May 03, 2011 | Whirlpool GGW9250PL Gas Dryer
Whirlpool dryer wont start
hello theres a long pin that sits inside the door make sure it has not snaped off if thats ok then the trouble may be caused by the capacitor next to the motor white cyilnder with couple of wires coming off
regards
shaun
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryer will not dry with full load, keeps kicking off
if your belt is slipping change the belt also check the felt and rollers make sure thay are turning freely the next step after that is change the motor thank you for useing fixya please rate me
Mar 18, 2009 | Whirlpool LGR7646E Dryer
Dryer only works until it gets really hot
Hello Joyce Dozier,
Some of the older dryers are the best and if you can keep them operational.. they can last a very long time.. Based on your problem description, you more than likely have a thermal cutoff switch that is cutting off power to the heater.. Over time, these thermal switches fail from age ( I can relate to that as well).. Anyway, please provide the Whirlpool model number and I may be able to track down the most likely suspects for you.. You , however, will have to rope a friend or family memeber in to replacing it... It could also be the themal sensor on the motor too..
I would unplug it and open it up to gain access to the motor.. and vacuum away all lint that may have accumulated around the motor and other areas... Provide the model number ( normally found on a tag someplace on your dryer..) and I will help you find a solution..
Regards
Rick
Jan 05, 2009 | Whirlpool Dryers
We must wait one hour to dry 2nd load
you have a bad motor the internal overload is cutting it off when the motor gets hot and that is why it takes about a hour for it to cool down before it will come back on the fix is replace the motor which is very expensive or buy a new dryer
Dec 28, 2008 | Whirlpool LGV4634JQ Gas Dryer
WHIRLPOOL GAS DRYER MODEL LGR7646E
sounds like your motor is bad or the start relay on motor.. dont think you can replace just the start relay on that motor
Nov 06, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
99 people viewed this question
Top Dryers Experts
