Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Frontload washer
I bought my washer last year and have misplaced my booklet. The clothes are being washed but the water will not drain or the washer will not spin. The display panel shows an F02 code and continues to beep. What can I do? Please help me I am desperate.
  • Anonymous Mar 16, 2014
    My kenmore elite finish washing my clothes, but when i open the door the washer didnt rinse and drain the water. i try to put it to rinse and drain again, but continue with the same problem...
  • Anonymous Mar 18, 2014
    f 35 code displays on my frontloading Kenmore elite washer
    President:
  • 878 Answers
Dea, F02 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. See if the washer comes back to life...Catriver..post back
Posted on Apr 28, 2007
  • JSAlberta Jan 23, 2011
    Had this problem on my front load washer, cleaned the pump filter as stated by Catriver, found a sock and coins in it, Problem solved. Thanks Catriver.
Exactly the fix need......thanks a bunch
Posted on Feb 24, 2008
Perfect Fix thank you!
Posted on Feb 22, 2008
Had same problem. Followed Catriver's advice on post (i.e., remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter and voila!). Found one sock, a quarter, and some other junk clogging the drain. Saved $55 house service call. Thanks all!
Posted on Dec 13, 2007
Perfect!!!
Exactly what was wrong with my machine. Easy fix!!!
Thanks so much.
Posted on Dec 08, 2007
I also was able to fix my problem in fifteen minutes with this solution. Thanks catriver. The only issue i had was catching the water...many many towels...
Posted on Oct 03, 2007
This was exactly the problem. Fix it in a matter of minutes. thanks catriver
Posted on Sep 24, 2007
Also, please check for any stucked clothe inside a washer'ssidfe( they are coverred with rubber). That had happened to me unfortunately. So double check before you get a holdn of a screwgun::)
Posted on May 06, 2007
What is best way to have my new Kenmore Elite Top-Loading washer (Model 796.3162) drain into a high pipe 7 feet from floor?
Nope, the drain pipe can be no higher than the Washing machine itself, the pump's to weak will not carry the water
Nov 19, 2014 | Kenmore Washing Machines
Kenmore Elite filling w/ Water when not running
your water inlet valve on the back where the water supply comes in is leaking. It needs replacing.
Jun 03, 2010 | Washing Machines
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
Our kenmore elite frontload washer drains too soon
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2009 | Kenmore Elite 45986 Front Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washer was disconnected, after reconnect, will not work.
Why was it disconnected in the first place, and what is disconnected, from the plug, breaker, where?
Easy fix can be to simply remover the power cord from the outlet for 20 minutes, make sure the water valves are on, both hot and cold, see if removing the power will reset the machine.
If not write back and we go from there.
Will
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
267 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
