Question about Cakewalk Music Creator 4
Not getting sound on Creator 4 Tutorial1/have headphones plugged
Also plugged in to Oxygen 49 midi
  • 22 Answers
Driver mode is probably wrong. What sound card do u have and what drivers does it use? Thats what you need to know. Then go to Options>audio>advanced and choose MME (or whatever your drivers are)) and then go back to Options>audio>general and run the wave profiler. You MUST do that for any changes to take effect. U should most def go to the Cake Forums, they can likely solve this very quickly for you. They'll ask the same questions tho- so please be ready with all that information
Posted on Mar 05, 2009
Why does my lowrey organ not make a sound after I have switched it on?
This is a generic answer for this kind of question.
When there is no sound
Check the obvious.
Is there a light on the organ indicating it is on?
  • Plug it in to a known working wall socket, switch on at the wall
  • Switch on at the organ, check light
  • Very old keyboards need a voice to be selected!!
  • Turn master volume up
  • Turn any other volumes up
  • i.e. lower manual volume
  • upper manual volume
  • swell pedals down
Sometimes a sustain pedal plugged into a volume pedal socket will mute the output, check this.
Headphones out, most headphones will turn speakers off, sometimes the headphone switch can be dodgy, work the headphone plug in an out a few times
There maybe a switch that turns off the speakers, look near the output sockets
Software volumes up, check display, if any.
MIDI instruments, check local control is ON
Still no sound?
Can you hear anything from the speakers?
Hiss or hum usually means the speaker is ok
Total silence may indicate speaker failure, but only if there is one speaker, as in older home organs, or smaller keyboards
Try headphones next, TURN Down master volume first just in case!
If there is some sound, very quiet and gross distortion then possible power amplifier failure.
If your instrument has any kind of line out as well as a headphone jack, try these.
The line output will likely be a pair of phono sockets,like you have on HiFi equipment, 1/4 inch, 6.35mm jacks, like the bigger headphone connector, a 3.5mm socket like the smaller headphone connector, or even a DIN connector on older equipment.
Connect these to the aux (or Line or CD) input on your HiFi, guitar amp or similar. (some times these outputs will drive headphones, usually you will only hear anything in the left side). If this works then it is very likely the power amplifier.
Further tests on MIDI equipped keyboards would be to see if the MIDI does anything.
If MIDI out works and there is no sound, and MIDI in makes a sound this points to local being off, buried somewhere in the menu will be local on or off, make sure it is on.
If MIDI out doesn't work then the failure is likely to be internal power supply or something else critical (not nnecessarily major).
Power amplifier failures in newer, low power, keyboards are often the power amplifier chips (i.c,s), older amplifiers may have just blown their fuses but one or more output transistors may have failed.
Cost of repair will be down to the time it takes to get to the fault, taking these to bits and putting them back can take a lot longer than the repair.!
Hope this helps, Chris the Fader
Aug 28, 2016 | Music
Oxygen 49 midi controller switches itself off when pressing "record" button on Ableton Live
Make sure only the midi input is set, not the output, and that the channel your using is armed. Otherwise the signal won't get through in record mode.
Apr 28, 2017 | M-Audio Music
I have a 3rd generation m-audio midi keyboard, when i switch it on the numbers keep on rolling.
See if the buttons that scroll the numbers MIGHT be stuck down. Try wiggling them sideways and see if it stops. Beyond this you will need to open the unit and inspect for possible cable problem or debris that might be shorting the signals from the panel buttons.
May 03, 2011 | M-Audio Oxygen 49 USB Midi Controller
Keys not responding on my keyboard.
It needs to be plugged in to a computer with a DAW to produce sound. The DAW converts the information sent by the controller about which key is pressed and how hard and converts it into sound with a virtual instrument
Jan 19, 2011 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
Try to get the keyboard to play through out my speackers
Since this has no audio output it will depend upon your computer to generate the sound using the audio system in the computer. You will need the driver software for the M-Audio to talk to the sound hardware in your computer and configure that to accept the MIDI inout from the M-Audio.
You will need to OPEN the volume and mixer controls for your sound board, unmute it, and enable the SYNTH channel and select "general MIDI".
As a test, download VanBascoe's Karaoke thing and play MIDI files to make sure your synth software is working. Then assign the MIDI source to teh USB input from the M-Audio.
Nov 01, 2010 | M-Audio Oxygen 49 USB Midi Controller
I cant get my knobs or sliders on my oxygen 49 controller working keys, octave and mode and pitch work fine, its just the sliders and knobs
Here is a link that might help:http://www.m-audio.com/index.php?do=products.directlink If your DAW isn't supported it might have a learn function that might help. Make sure you download the latest update.
Oct 18, 2010 | M-Audio Oxygen 49 USB Midi Controller
Hello, I have the MIDI kit and it is pluged in, how do I get the music to the keyboard or keyboard music to the computer? I want to recoard some music for singing, please help. Thank you, Princess
In Device Manager (I am assuming you are using Windows XP) you will find your MIDI devices under Sound, Video and Game controllers. It is possible that the MIDI port has not been enabled in BIOS, I have had some PCs where this had to be done first. If Fruity Loops doesn't give you any available MIDI port to use it does not sound as though the PC knows it's there or has installed the driver properly. Start in Device Manager - if there's no MIDI port there or it's not working for some reason you'll have to fix that first.
Mar 03, 2010 | Cakewalk Music Creator 4
Midi keyboard sound quality bad
you are likely running it thru a soft synth. Check the help files there is a section in there on "using soft synths" that will explain it more fully. Plus a usb connection can sometimes be problematic (not always). But the tutorial in the help files will tell u how to use the sounds from the piano instead of the MIDI sounds
Dec 17, 2008 | Cakewalk Music Creator 4
Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Mar 13, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Cakewalk Music Creator 4 Logo
102 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
