Question about Carrier 36KCARMS Air Conditioner
Only blows hot air inside
My Carrier Split System Air Con, was working fine last summer but this time when I tried to switch it on it only blows hot air inside and the outside unit blows very cold air outside. It look as if the process has reversed itself. Could you help me with an indication as to what is wrong. It was never used during winter (heating). Thanks
  • Ken Bledsoe May 11, 2010
    Sounds like the heat pump is working instead of the A/C.. Hate to ask but the thermostat is set to A/C?
  • 61 Answers
Set thr thermostat to AC instead of HEAT.
Posted on Jan 02, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Cruze - hot air from driver side and cold from passenger
Do yourself a favor an take it to repair shop before you mess it up or hurt yourself !
May 14, 2015 | Cars & Trucks
My heat isnt working now but in the summer time my ac works. but last year my heat woulodnt work but then one day started working. then the summer time my ac wouldnt work then one day started working an...
what kind of air con is it. it would be a sticky reversing valve either from inside the valve or the solinoid pulling it siting on the valve. http://t3.gstatic.com/images?q=tbn:SMSfcwrA_p4i6M:http://www.daviddarling.info/images/reversing_valve.jpg&t=1
Nov 10, 2010 | Heating & Cooling
I charged my ac last summer, worked great. This summer the 2 vents on the passenger side work great, very cold. The 2 vents on the drivers side blow air but not cold, just like the ac is not on?
One of your Actuators inside the dash that control the A/C Heat doors/ Baffles that open or close, to either give you hot or cold air has failed. Find and replace the failed Actuator and it should work fine.
Jun 24, 2010 | 2007 Hyundai Tiburon
Carrier 36KCARMS Air Conditioner Logo
472 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
