Question about GE DVL223GB Gas Dryer
GE Dryer DVL 223GB1WW
My dryer runs and heats, but there is a thumping sound when the drum turns. I took the top cover off and the belt looks okay at first glance. (1) What else should I look for on the belt to establish if it is bad? (2) What else could be wrong with the dryer? Could it be a clogged exhaust making the thumping sound? (3) Also, could you direct me to a service manual to repair this myself? The dryer manual is not comprehensive and only provides very general information. (4) Does this seem like a serious problem?
  • Anonymous Mar 22, 2014
    My dryer just started making a thumping sound whenever I run it. It is about 4 years old & has never been moved since I got it.
Ge dbxr463eb1ww how do i install an out let for a electris dryer. it came with a 3prong and a 4 prong, the dryer says 120/240 and 120/208. theres only a standard 110 out let, what do i do
Posted on May 31, 2010
    Novelist:
  • 114 Answers
ALWAYS UNPLUG ANY APPLIANCE AND TURN OFF THE GAS VAVE BEHIND THE DRIER BEFORE ATTEMTING TO MOVE IT. I HAVE REPAIRED GAS FIRED EQUIPMENT FOR YEARS ...ALWAYS MAKE SURE YOU LOCATE YOUR GAS METER IN THE HOUSE OR OUTSIDE AND HAVE A ADJUSTABLE WRENCH READY. I HAD A GAS VALVE BREAK-OFF IN MY HAND AND, A FLEX-LINE BREAK WHEN I MOVED A DRIER ... I WAS LUCKY I KNEW WHERE THE METER WAS. YOU CANT BE TOO SAFE !!! THE ONLY WAY TO CHECK A BELT IS TO REMOVE IT ... THERE IS A SEPERATE ADJUSTABLE PULLEY THAT ADJUST THE BELT TENSION (USUALLY LOCATED AT THE BOTTOM OF DRIER BELOW THE DRUM NEAR THE DRIVE MOTOR) YOU MAY OR MAY NOT HAVE TO LOOSEN THIS ADJUSTABLE PULLEY TO REMOVE THE BELT. FIND A CLEAR AREA WHERE THE BELT IS NOT ON THE SRUM AND PRESS ON THE BELT ... THERE SHOULD BE NO MORE THAN 1/2" OF "PLAY" ( MOVEMENT)IN THE BELT AFTER YOU REMOVE THE BELT ... TURN IT IN-SIDE OUT. AND SLOWLY ROTATE IT ... INSPECTING EVERY INCH FOR CRACKS AND EVSERSIVE SIDE WEAR. IF THERE ARE ANY CRACKS, VISABLE PLYS (LAYERS) OF THE BELT CAN BE SEEN, OR IT IS REAL SHINNY ON THE SIDES... THE BELT SHOULD BE REPLACED. WHILE THE BELT IS OFF ... USE YUR HAND AND SPIN THE DRUM TO CHECK FOR ANY WOBBLE.... THERE SHOULD BE NO WOBLING ... IF THERE IS IT MAY INDICATE BAD BEARINGS... HOPE THIS HELPED
Posted on Apr 28, 2007
Thumping sound when drying?
change your belt or replace the spring that tensions the belt
Jul 13, 2017 | General Electric GE DBVH520EJWW Electric...
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
Dryer making a thumping noise, heating okay, drum is going round. could drum be out of round and thumping on the rollers
the roller is out of round instead for the internal bearing has dried up and locked tight making the belt to burn the nylon roller flat in the spot the belt rides on. It will be neccessary to replace the belt and the roller as well
Feb 20, 2010 | LG DLE2532W Electric Dryer
It will turn on but the tumbler wont move or heat up
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, if the belt is broken or slipped off of the motor or idler arm pulley then the dryer will not turn or heat up.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Oct 27, 2009 | GE Profile Harmony DPGT750EC Electric...
Belt and drum turns but with a thumping sound.
check the idler pulley, it could be broken. Also check the inner side of the belt for a chunk missing.
Oct 03, 2009 | Maytag Dryers
Dryer makes a loud thumping noise when running
A thumping sound in your dryer could be caused by a flat spot on one of the drum support rollers. It can also be caused by a problem with the drum. An idler pulley on for the belt on the drive motor can also make a thumping noise when the dryer is running. Check to see if the cabinet is properly leveled with 4 feet firmly on the floor. Push down on opposing corners to check for play. Adjust the leveling legs if necessary.
Without a model number of your Whirlpool dryer, I am not able to provide much more help. If your dryer has the lint filter that pushes down into the top panel of the dryer, then here are a few tips for accessing the inside of the cabinet:
  • Unplug the dryer to disconnect electrical power.
  • Pull the lint screen out.
  • Remove the screws that secure the top panel to the lint screen housing.
  • Use a putty knife to release the clips on the front of the top panel (about 4" in from each side) that secure it to the dryer frame.
  • Hinge the top panel up and back.
This will provide to access to the inside of the dryer cabinet. Manually spin the drum in a counterclockwise direction and see if you can determine the source of the noise.If you need more help, resubmit your question with additional details and the full model number of your Whirlpool dryer.
Aug 08, 2009 | Whirlpool Dryers
Dryer drum making thumping noise
My dryer just started making this noise. So I opened the back up to try to figure out what it might be, and when I opened it I saw something. It was part of the belt that drives the dryer. There are grooves vulcanized to the belt, and a small section of grooves or cogs I think is what they are called had come apart from the belt and what laying there on the floor of the dryer. But I ran it and timed the thumps in my head to get it to stop right on the "thump". Sure enough there was a small 1/2'' appx. of belt Cog missing, so the "thump" came from when the belt came around to the motor and the pulley hit a divit in the belt, "thump". So needless to say I need to replace the belt soon before it breaks completely. I figure that it looks like someone may benefit from knowing what the noise is. Now its off to find the proper belt and look up how to change those things...Good luck to those reading this.
jiujitsujd@aol.com
Jan 16, 2009 | LG DLG3788W Gas Dryer
To access these dryers you open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On these dryers there is a friendly rear hatch to help you replace the idler. As far as the thump tha could be from anything. Once you get the dryer apart you should be able to locate and remedy the problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | GE DBVH512EFWW Dryer
Brown burn spots on Whites
Hot spots in the drum perhaps. Check for a loose heating element.
May 06, 2017 | Dryers
GE DVL223GB Gas Dryer Logo
183 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
